Old 01-18-2010, 12:52 AM   #1
Getter-Done
Getter-Done's Avatar
Disc Brakes on 14-Bolt Full-Floater
I'm New to the Forum
I have Owned Several 1974 to 1985 Trucks + 1 (1976 Blazer)in my 20 years or so(driving) // 4/ Wheeling/
Glad to see So many Chevy Trucks Fixed-Up on this Forum.
I would like Idea's on Disc Brake conversion for 1978 14 Bolt FF Axle.
I have brackets from http//www.ruffstuffspecialties.com from E-Bay
I have 1978 Edorado/Cadillac Calipers (from Pull-A-Part) for Core & Also have Levers & springs I will need for E-Brake Set-Up
Now my Question isoes any body have Pictures of this swap or Info???????
#1-Brake hose Set-Up---AN Fitting or Regular Stuff
#2-E-Brake Set-Up---Try to Hook up to Foot E-Brake or CUSTOM Lever
Thanks in Advance
Getter-Done
Old 01-18-2010, 11:18 AM   #2
Slick17
Slick17's Avatar
Re: Disc Brakes on 14-Bolt Full-Floater
I think this has been done on here before. I would like to see pics as well.
05 Chevy 3500 Crew Cab Dually
Sold 1984 Custom Deluxe K/30, 350 SBC with 4 Speed, 6" Lift, 35" Boggers, Headmen Headers, Custom Full 3" Dual Exhaust, Qualitex Buckets with Flip Center Console
Slick17 is offline   Reply With Quote
Old 01-18-2010, 11:01 PM   #3
Getter-Done
Hey Slick17
I plan to buy a Camera Also. Hee Hee Hee
I like your Truck
Getter-Done
Old 01-19-2010, 02:47 AM   #4
ghettoluxury
ghettoluxury's Avatar
When I did my swap I used the hoses for the front calipers and re-ran my brake lines so that they went through the frame like the front does.
Pull the axle shaft out
Pull the brake drumb off
Remove the Hub (this requires a special socket)
Take the brake line loose from the wheel cylinder
Remove the brake backing plate
Press the studs out of the Hub with a hammer and punch
Put the new rotor on the back side of the Hub and press the studs back through
Mount your new bracket from Ruff Stuff so that the bleader is facing Upward (the bend should be towards the wheel)
Put the hub back on
Put the caliper and pads on
Re-install the axle shaft
Repeat on other side
As for running the E-brake lines I don't know because I used front Calipers from a Dana 44
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 01-19-2010, 11:24 PM   #5
Getter-Done
Thanks Getto Luxury
You gave me several Idea's
I probably need to stick with Rubber lines.
Put the hub back on
Old 01-20-2010, 08:58 AM   #6
ghettoluxury
Originally Posted by Getter-Done View Post
Thanks Getto Luxury
No prob, this it what we are here for.
Old 01-19-2010, 03:20 PM   #7
fun in dirt
fun in dirt's Avatar
I saw a good idea the other day that I'm gonna do for an e-brake: Just run a portion of the rear brake line into the cab (I'm going to have a center console, so mine will come up into it) and put a valve on it. That way when you stop, before taking foot off the brake, close that valve & it'll hold the back brakes.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
[B]'85 C10 [B] "Corpse"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 01-19-2010, 06:57 PM   #8
BIGphillip79
BIGphillip79's Avatar
the line lock idea for a park brake is good, but not as an Emergency brake. If you lose your master cylinder you got neither. If I'm not mistaken, for inspection the E-brake must be mechanical.
If it ain't broke broke don't fix? Get a hammer.
'89 K1500, Reg. cab/long bed, 350/700r4, 285/75-16.
BIGphillip79 is offline   Reply With Quote
Old 01-19-2010, 11:41 PM   #9
Getter-Done
That's what I Want a Cable System Either foot or lever Operated.
Thanks Big Phillip
That backs up my thinking on I need E-Brake
Old 01-19-2010, 11:30 PM   #10
Getter-Done
I was Thinking more of Cable E-Brake. But that is Definately an Option.
Thanks for the Idea.
Old 01-20-2010, 08:25 AM   #11
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
Google Mico brake lock. I had several on different tow trucks. Not an emergency brake, but will hold your truck as anchor to winch from/to. Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 01-20-2010, 09:17 PM   #12
Getter-Done
Thanks Big Port Jimmy
Fun in the Dirt also mentioned
this I found one on E-Bay I think I will go with it.
Because I do some Winching from time to time.
Old 01-21-2010, 11:45 AM   #13
fun in dirt
Yeah that's exactly what I had in mind, just didn't know who made such or how to go about searching. I really like the lever lock style ...THANKS!
'85 K30 "Big Nassy"
'06 C1500 WT...DD
Old 01-19-2010, 09:11 PM   #14
cobinder
Everything is work in progress
cobinder's Avatar
You should swap out your master cylinder for a 4 disc model. Some peeps don't and get away with it. But it you really want the full benefit of the 4 disc's, swap the MC
Good luck with your truck!
How much?! It's just an old truck part!!
49 International on a 80 GMC 3/4ton 4x4 chassis
48 International KB-5 2 ton dump bed
04 Honda CRF "500"
09 Honda CRF450 fuel injected rocket
03 Suzuki hayabusa carbonfiber wheeled monster.
02 Ford diesel stretch van (toy hauler)
01 38' Monaco diesel pusher motorhome
cobinder is offline   Reply With Quote
Old 01-19-2010, 11:45 PM   #15
Getter-Done
Have you got a Part # for Master Cylinder????
Thanks in Advance
Getter-Done
Old 01-21-2010, 01:16 AM   #16
cobinder
cobinder's Avatar
Thanks in Advance
Getter-Done
MC off a mid 90's p30 (chassis cab van) is the one recommended to me and it works great.
Napa #UP 390278
04 Honda CRF "500"
Old 01-20-2010, 11:37 AM   #17
doug70
Check this out.
http://www.pirate4x4.com/tech/billav...b_disc_brakes/
Btw, you can use 78 caddy eldorado calipers for cable parking brake.
Doug
doug70 is offline   Reply With Quote
Old 01-20-2010, 01:01 PM   #18
Slick17
Slick17's Avatar
I've read about the caddy calipers and alot of people that have used and ran them say they are junk. They have said by the time that you spend the money on finding them gathering all the parts needed that you could buy a better set up.
I'm thinking about doing what Ghettoluxury said and for a E-Brake use a transfer case disk brake. Now granted if your axle brakes I won't have a E-Brake but if that happens I won't be driving it and I can use a brick lol.
Thanks Getter-Done.
Old 01-20-2010, 10:14 PM   #19
Getter-Done
[QUOTE=Slick17;3745160]I've read about the caddy calipers and alot of people that have used and ran them say they are junk. They have said by the time that you spend the money on finding them gathering all the parts needed that you could buy a better set up.
Thanks Slick 17
I will read up on that caliper problem /I seen something about Lincoln Calipers On the Thread?.I don't have much money in it yet just $18.00 at pull a part and $50 Bucks on Brackets. I seen that Transfer case Brake,that's Awesome.
Thanks again,
Getter-Done
