Dash Speaker
Are the dash speaker hard to change on a 72 GMC.
Re: Dash Speaker
I guess no body has changed them.
>130dB Moderator
Re: Dash Speaker
Sorry, I've never worked on one personally. I would imagine that it isn't very hard to do. Should be pretty straight forward. 4 screws, 2 wires and a little time.
I'm not sure waht the factory size or power rating is, but it can't be very big in either case. Look at LMC truck or Clasic Industries for a replacement speaker. Both should have a couple options available.
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
Re: Dash Speaker
I replaced mine with a "custom" plate that houses (2) 3.5" speakers. It isn't hard to change out, but may test your patience. You will need to take out the OG radio if still in to get the speaker out. At least I wasn't smart enough get around it. What I did was take out the speaker and used it as a template and traced it on to 1/4" MDF board. Used the 3.5" speaker as another template to cut out the speakers in the MDF board. Painted the MDF board rattle can black and reinstalled it.
The Red Menace
Re: Dash Speaker
Can you clarify what you are trying to do? Are you trying to get the factory speaker out of the dash? What are you planning on replacing it with?
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current) 1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former) 1968 C-20 - 307/3sp column (Dad's when I was a kid) "Driving is like coloring. Things get messy if you can't stay inside the lines." |
Grandpa in the rustmobile...
Re: Dash Speaker
What're some options for putting a speaker there? or speaker(S)
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
The Red Menace
Re: Dash Speaker
Instead of stock you can put a dual cone stereo speaker in the stock dash location. If you don't want dash speakers, you can go with kick panel speakers or even put in a headliner with built in speakers.
Re: Dash Speaker
As my post stated I have (2) 3.5" speakers. I believe LMC, brothers, and the like make replacement speakers.
Re: Dash Speaker
red71c10 I'm just putting in a modern speaker made for the dash, where the stock one was at.
Re: Dash Speaker
I just installed 2 four inch 200 amp speakers in the factory spot under the dash, yes it will test your patience and put you in positions you never thought you would do :lol I removed the radio, the ash tray and mount and the heater controls to get to it.
#11 | |
Re: Dash Speaker
Re: Dash Speaker
Re: Dash Speaker
The Red Menace
Re: Dash Speaker
OK. You might need to fab a bracket or come up with some creative mounting. I think when I did what you are doing in my old '68, I pretty much had the speaker sitting on top of the radio.
#15 |
the pollock
Re: Dash Speaker
i made my plate out of sheetmetal and pop rivets, i have two 3.5's in the center speaker hole and one eachin the stock locations.
i have a total of 8 components in the cab..
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
#16 |
the pollock
Re: Dash Speaker
mine had 3 3.4 kickers in the dash
and 4 6.5's in the rear, i made my own corner brackets out of sheetmeatal (easy =-)) and the speakers were bought on a kicker sale for 250 total for all 8.. the second part to this is adding an amp for the components (100 with wiring etc) and then a sub with amp (probably a JL 8in which is amazing.....) for about 400 ish.... entire stereo will be done for about a grand... but will be great for my little cab
