Old 01-30-2010, 01:10 AM   #1
AusTx68
AusTx68's Avatar
Running exhaust in front of rear tires
I would like to run 2 1/2" exhaust along the inside of my frame, thru my ECE drop crossmember and exit just in front of the rear tires. My muffler of choice is the Flowmaster Super 44. The muffler comes in a straight thru or staggered inlet/outlet design. I'm not sure which one I need to run the exhaust the way I want it. Do I get straight thru or staggered.
I'd like to see photos of how the exhaust is run if you guys have them.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 01-30-2010, 06:14 AM   #2
Blackbird66
Re: Running exhaust in front of rear tires
too much snow on the ground to go take a pic, but this is the set up I have. My mufflers are the original 40 series center in off set out. Pipes turn @45 angle and exit in front of rear wheel. I like 'em. I don't have a cross member though, as I have a 5 speed matted to the original bell with rear mounts.
Blackbird66 is offline   Reply With Quote
Old 01-30-2010, 08:16 AM   #3
rob32472
here' s mine cant see from the pics but it dumps just after the mufflers rt in fron of the rear end
rob32472 is offline   Reply With Quote
Old 01-30-2010, 09:19 PM   #4
AusTx68
AusTx68's Avatar
Good photo. I can tell I'll probably need staggered inlet/outlet
Are they dumping straight down or do they turn out in front of the tires?
Old 01-30-2010, 11:17 PM   #5
rob32472
they turn str down
Old 01-31-2010, 08:28 AM   #6
Blackbird66
no, original 2 chamber 40 series
Old 01-30-2010, 09:34 PM   #7
69 longhorn
Its gonna be loud as he!!.....If thats what you like , go for it if you like something a little "tamer" running through town(bark when you stand on it), I would suggest a set of Dyno max Superturbo's with your side exit exhaust. Also, an H or X pipe before the muffs will help mellow the note, & give a little more power in the mid range. crazyAL
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 01-30-2010, 10:01 PM   #8
AusTx68
AusTx68's Avatar
LOL, that's what I'm looking for! This is by no means a daily driver and I want an aggressive sound.
Old 01-30-2010, 10:39 PM   #9
69 longhorn
Just a suggestion, I ran a 461" Olds BB through the system I mentioned(in my longhorn ,early 90's). It was one of those "rattle the windows" in any building you pulled up next to.....nothin like BB power crazyAL
Old 01-30-2010, 10:44 PM   #10
Blackbird66
mine is a little on the loud side, but not rattle the windows loud. it's just loud enough to drown out the wind noise at highway speeds.
Old 01-30-2010, 10:57 PM   #11
AusTx68
AusTx68's Avatar
Are you running the Supper 44s?
Old 01-31-2010, 09:12 AM   #12
fdbdw
fdbdw's Avatar
Im running long tubes w/2.5 inch pipes and supper 44s, 3inch tail pipe dumps before the rear tires, I went with off set inlet/outlet worked out great and my PO is they sound perfect, not to loud
fdbdw is offline   Reply With Quote
Old 01-31-2010, 09:31 AM   #13
You meed the offset in (to hug the frame) and center out.Double offset will work,but not necessary.
