Old 02-08-2010, 07:42 PM   #1
79SWBchevy
Flip Kit Questions.
.Is C-Notching a frame necessary when doing a flip kit? Can it be avoided?
Thanks alot in advance.
79SWBchevy is offline   Reply With Quote
Old 02-08-2010, 07:50 PM   #2
grinch4om
dang its hot
grinch4om's Avatar
Re: Flip Kit Questions.
if you carry loads, yes. you will have to remove the bump stops and their mounts
grinch4om is offline   Reply With Quote
Old 02-09-2010, 01:00 AM   #3
slugish
Slugish
x 2
slugish is offline   Reply With Quote
Old 02-08-2010, 09:15 PM   #4
3r!c84
Badass
3r!c84's Avatar
also the amount of leaf springs you have.i have 4 and i got a good 6inches between the axle and the bumpstop
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 02-08-2010, 09:35 PM   #5
thehitchmaster
thehitchmaster's Avatar
I would use a notch, I hate bottoming out. my 2 cents
http://www.gulftruckinc.com
thehitchmaster is offline   Reply With Quote
Old 02-09-2010, 05:37 PM   #6
low86c10
i hauled around a 36" walk behind lawn mower in mine and all i did was cut the bump stops/mounts off never hits
low86c10 is offline   Reply With Quote
Old 02-09-2010, 06:49 PM   #7
3r!c84
Badass
3r!c84's Avatar
lots of room
-00 Saturn 5spd
1/4:13:90
Old 02-09-2010, 07:09 PM   #8
chevymotocross
chevymotocross's Avatar
That looks like a good amount of room. As was stated, a big factor of clearance has to do with the # your leaf pack as well.
Thing is though, atleast with my truck, that clearance is sufficient for an empty bed or hauling around a motorcycle and gear. Every now and then though, atleast with me, something comes up and I have to haul a yard of mulch or something. That's when I don't want a suspension modification not allowing me to use my truck as a truck. So, if I do decide to go with a flip kit instead of shackles/hangers, I will install a small C-Notch.
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch
chevymotocross is offline   Reply With Quote
Old 02-09-2010, 07:15 PM   #9
3r!c84
Badass
3r!c84's Avatar
motocross:also how do you like the heavyer front sway bar? notice any thing
im thinking of putting a 3/4 ton one my truck
-00 Saturn 5spd
1/4:13:90
Old 02-09-2010, 07:20 PM   #10
chevymotocross
It was night and day but that was because my truck had no sway bar
Old 02-09-2010, 07:28 PM   #11
3r!c84
Badass
3r!c84's Avatar
like riding a bike with no training wheels
-00 Saturn 5spd
1/4:13:90
Old 02-09-2010, 09:23 PM   #12
79SWBchevy
ok guys thanks alot.
i think i would rather do shackles and hangers to drop it 4" because 5" seems like too much for me but im not sure until i get the wheels. i will be running 20"s.
thanks for your input.
Old 02-09-2010, 09:42 PM   #13
3r!c84
Badass
3r!c84's Avatar
how tall of wheel and tire set up?
-00 Saturn 5spd
1/4:13:90
Old 02-09-2010, 09:49 PM   #14
79SWBchevy
im not sure yet. will probably be boss 338's or similar in 20". not sure of tire. probably 45 all the way around
Old 02-09-2010, 09:51 PM   #15
bigblock73
yeller
bigblock73's Avatar
You will likely regret a shackle/hanger drop. S/H drops really don't allow you to lower it more unless you want to install drop leafs, or take out the S/H all together and go with a flip. Just about everyone who does a S/H drop usually want to go lower once installed...including myself. Do a flip, and be done with it. If you want more, then install drop shackles.
bigblock73 is offline   Reply With Quote
Old 02-09-2010, 10:11 PM   #16
79SWBchevy
if necessary, is there anyway to add height after the flip?
Old 02-09-2010, 10:18 PM   #17
3r!c84
Badass
3r!c84's Avatar
add a leaf or put in a helper air bag
-00 Saturn 5spd
1/4:13:90
Old 02-09-2010, 10:11 PM   #18
3r!c84
Badass
3r!c84's Avatar
x2
go big or go home
-00 Saturn 5spd
1/4:13:90
Old 02-09-2010, 10:22 PM   #19
low86c10
do a flip kit, you wont regret it
Old 02-09-2010, 10:29 PM   #20
79SWBchevy
i want to rear fenders slightly above or level with the very top of the tire. I guess its one of those things where you just have to buy the wheels and tires and see where to go from there.
thanks
Old 02-09-2010, 10:34 PM   #21
3r!c84
Badass
3r!c84's Avatar
thanks
well how tall of a tire will it be and ill give you a guesstament of what it will look like with my truck
-00 Saturn 5spd
1/4:13:90
Old 02-09-2010, 10:31 PM   #22
low86c10
heres mine
Old 02-09-2010, 10:34 PM   #23
79SWBchevy
is that with a 5" flip? how tall would you say your tires are?
Old 02-09-2010, 10:36 PM   #24
79SWBchevy
roughly 27" tall.
Old 02-09-2010, 10:44 PM   #25
3r!c84
Badass
3r!c84's Avatar
mine are 28in high.the first pic has a bunch of weight in the back so it sits a little lower
as you can see the crap in the back(and the pos elco)
-00 Saturn 5spd
1/4:13:90
