Old 03-18-2010, 01:11 PM   #1
dammitmitchell
the pollock
dammitmitchell's Avatar
Power steering grrrr!!!!!!!!!!!!
allright so here we go
pulled the PS motor to clean it up and get crap out of it, put it back togther and reinstalled, replaced power steering pump due to screaming bearings..
guys at the store swear it cant be a bad pump, but all i did was pull the PS motor and remove the top cover with the adjuster screw and clean the garbge out of it, and freshly installed an new PS pump.
oh and lifted the truck and operated the steering to relieve aire bubbles, truck running and with it off.
so here's what it's doing.
it is profusely pouring out of the cap, no matter the start level it just pours out of the ps cap.. .constantly... im sick of it... please help!
my next step is to replace the PS pump again and raise hell for a bad part, but! it's a pain in the ass because my chebys now my DD again
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 03-24-2010, 12:30 PM   #2
Doc Harrel
Re: Power steering grrrr!!!!!!!!!!!!
You might check to see if the high side hose is installed in the correct port on the gearbox. If the high side hose is going to the low (return) side of the gearbox the checkvalve could be causing your fluid to build up pressure inside the pump. It might also be a clogged highside hose, try running a wire through it
Doc Harrel is offline   Reply With Quote
Old 03-24-2010, 06:55 PM   #3
dammitmitchell
the pollock
i replaced the pump tday (finally) and the problem left, the high side hose only fits in that hole, the return hoze the same...
cleaned both hozed and checked for clogs nada,
pulled the "cap" off the steering box and reinstalled it. i did this all in one shot so i dunno waht really fixed it, but im assuming that it was the "new" ps pump
Army vet 02-08
Old 03-25-2010, 01:50 AM   #4
Doc Harrel
Well atleast you fixed it!
Old 03-25-2010, 04:14 AM   #5
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Wow crazy glad to hear that you got it fixed bud. I hate having new parts that are bad that totally sucks!
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
