Old 01-07-2001, 04:04 PM   #1
Fast68Chevy
Fast68Chevy's Avatar
Post Tach/clock dash ??
Got a question about '76-'78 instrument panels....
Is there a such thing as a mechanical oil pressure/factory tach/factory clock dash ??
If so, where would the fuel gauge go, as there wouldnt be any small holes to put the fuel gauge in, because of the addition of the clock ?!?!?!??!!
I have the opportunity to build a mechanical oil gauge/clock/tach gauge, because I have aquired all three gauges today in a deal I made.
If a panel can be built in this configuration, would it be worth anything ??
Or is this even possible ??
Thanks for any info
Fast68Chevy is offline   Reply With Quote
Old 01-07-2001, 07:18 PM   #2
Chevyman69
Vortec 350's Suck
Post
If you take the tach from a 2 ton and up truck usually they had a vacuum gauge or a air pressure guage and the fuel gauge is built into the tach at the bottom which allows an empty pod which you can put a clock or vacuum gauge in.
69 CST, 402 steel crank, heavy rods polished ported heads 2.19/1.88 should be 450+ 700R4 373 Posi buckets/console tilt tach 4wheel discs
Daily Driver: 92 Chev 4x4 350 auto
69 Chev CST 10 reg cab lwb
Daily Driver: 92 Chev Reg Cab LWB Silverado 4x4, K.I.A 7:51 AM 04/22/03
Will be resurrected
Chevyman69 is offline   Reply With Quote
Old 01-08-2001, 01:33 AM   #3
Fast68Chevy
Post
Interesting...... so no dash like that for 10-30 series ?? hehehehe.....
Old 01-08-2001, 01:55 PM   #4
Fast68Chevy
Post
Oh, another question....
Will a '76 A/C cab underdash wiring harness work for a 78 Non A/C cab ??
If not, how can I make it work ??
Got a person I know who just bought a 78 K-10 LWB, and the PO added lights like marker lights, etc, and really messed the wiring up, the instrument panel gauges all dont work, even after replacing the pannel with another one.
And I trhink the harness in the 76 is prolly good.
They all act as if they are disconnected.
I figured the whole harness gonna need replacement.
Any ideas/tips/info ??
[This message has been edited by Fast68Chevy (edited 01-08-2001).]
Old 01-15-2001, 12:19 PM   #5
ManicM
Post
Try doing a search on E-Bay for 73-87 Chevy pick ups...I came across some dashes with large tach and small gas guage. Going prices around $125-150
ManicM is offline   Reply With Quote
