Old 01-16-2001, 06:31 PM   #1
69Custom
69Custom's Avatar
Question Truck wont start HELP ????
On Sunday I started my truck and it ran for two minutes and then I heard a clunk and it shut off and I have replaced the hole coil, cap, rotor, plugs, wires and carb and it still wont start. I have even dumped gas down the carb and it just cranks. the cranking is strange though. It will crank and all of a sudden it will stop. Do you think that it is the starter?
Thanks in advance
Jerr
New Project
  • 69 Chevy SWB, 67 front clip, 4 wheel disc brakes, 350 with 5 spd. (current project)
  • 72 Blazer 4WD 307/3 spd, PS, PB, Posi (recent purchase)
  • 83 Chevy SWB 350/200r4, buckets (daily driver)
1972 Chevy C-10 Short Stepside
6Cyl, 3 spd, not opts
(Current Project)
Now a 2004 SSR 5.3L with 4L60E
Now Ididit tilt- ps, pb
2002 Saturn L200
2006 Toyota Highlander HYBRID
69Custom is offline   Reply With Quote
Old 01-16-2001, 07:18 PM   #2
Fast68Chevy
Fast68Chevy's Avatar
Post
Which truck? the 83? have ESC in it ?
If it has ESC, is the oil pressure switch good?
Fast68Chevy is offline   Reply With Quote
Old 01-16-2001, 07:36 PM   #3
69Custom
69Custom's Avatar
Post
It is the 83, but it doesnt have the original engine in it. It has a mid 80's monte carlo engine. The comuter is not hooked up either.
(Current Project)
2002 Saturn L200
Old 01-16-2001, 10:35 PM   #4
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
Red face
Check to see it your rotor is turning constant with the engine, could have had a timing chain jumping gears. then see if it getting spark. Let su know how you make out
71 custom 20 - 307 3onthetree (bone stock & 4 sale or trade)
56 working Street rod (under construction)
92 Olds 98 land yhat..(wifes)
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 01-17-2001, 07:28 PM   #5
69Custom
69Custom's Avatar
Unhappy
I still cant get it to start.....urg
My brother was able to see if it is getting spark tonight and it isnt.....why?
I replaced the coil and just about the whole starter system except for the starter. Right now when I try to start it, it will attempt to turn over and seeze, the then I try again and it will turn over then, but weekly.
Jerr
(Current Project)
2002 Saturn L200
Old 01-20-2001, 06:29 AM   #6
bigblue
Post
have you made sure the distributor is getting power, if you have no spark at the plug you need to start moving back thru the ignition system
maybe you do not have a wire hooked up securely after swapping cap,maybe one just fell off or is shorting out somewhere before it gets to distrib.
also watch all that cranking it does not take to long to drain your battery that way
do you know where the clunk sound came from
70 GMC 1/2 ton 350/350auto 2wd lwb (bigblue)
74 GMC 1/2 ton 350/350auto 2wd lwd
93 Chevy k1500 z71 ext cab 350/auto swb
67 Plymouth fury 2dr 318/auto
bigblue is offline   Reply With Quote
Old 01-20-2001, 09:52 AM   #7
69Custom
69Custom's Avatar
Talking
I am in the process of checking the wires now. I think the clunk was my carb breaking. After the clunk when I tried to start it right away it wouldnt so I looked under the hood and the gas was shooting out of the carb and not in. That is what I think the clunk was.
Jerr
(Current Project)
2002 Saturn L200
