Old 05-12-2010, 08:21 PM   #1
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
4x4 spring questions
I have 1/2 ton 4x4 but i need it to tow a lot more so i got a rear spring system from a 1 ton suburban but heres the problem. will my 1/2 ton rear springs fit the front (old ones will be to low and are worn out).
if not what is the difference in size from point to point. if i cant i will be making my own front springs (have a few trash truck springs) i know i can make them work by taking all the old springs out and building my own set.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 05-12-2010, 09:34 PM   #2
USSkoval
Re: 4x4 spring questions
There were no 1ton Suburbans, so I'll assume it was 3/4ton. The rear springs should be 56", your stock ones are 52". You would just need to move the rearmost hangers back on the frame 4 inches.
You can use your stock rears on the front, but...
You will gain 3 or 4 inches in height.
You will need to move/build/buy front spring hangers.
Might have to relocate the shackle mounts in the frame.
Need longer shocks.
Convert to crossover steering which involves another list of things to do/buy.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'79 K30 Crew Cab Dually
'84 C10 Short Stepside
'88 K20 Suburban
USSkoval is offline   Reply With Quote
Old 05-13-2010, 06:21 AM   #3
LONGHAIR
The suspension is not the only issue. No matter what you end-up doing to "hold up" the weight, you still have to stop it. You need to concentrate on brakes as much or more than springs.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 05-16-2010, 10:35 AM   #4
Srubydo1986
The Crazy Machanic
this is very true and i tend to do so but only running 33 inch tires under the truck but for some reason they rub most like front springs ar very worn out.
and as for what USSkoval said swapping rear springs can be done and very easily just doing the front wont be
*You will gain 3 or 4 inches in height. (its actually how much high i would like)
*You will need to move/build/buy front spring hangers. (hmm that might be hard)
*Might have to relocate the shackle mounts in the frame. (got a place in town that can build me a few so no problems there)
*Need longer shocks. (already covered)
*Convert to crossover steering which involves another list of things to do/buy. What is this
05-12-2010 08:51 PM
as for front spring what if i just built springs, such as taking the front spring apart and building from that leaving the stock hangers alone kinda like a helper spring but in all honesty just adding more leafs
newest additions
