Old 06-03-2010, 12:52 AM   #1
GOPAPA
GOPAPA's Avatar
What Goes In This Hole ?
I am talking about the hole in the firewall right above the wire that is comming out for the heater fan . It is about a 2 inch diameter hole .
I have looked up "Search" and none of the firewall pictures have a hole in this area exposed and labeled,, gp
A closer up LOOK
GOPAPA is offline   Reply With Quote
Old 06-03-2010, 01:06 AM   #2
breeh
Recovering 67-72 Addict
breeh's Avatar
Re: What Goes In This Hole ?
Pretty sure that somebody added that after it left the factory.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 06-03-2010, 01:21 AM   #3
OldCreek
OldCreek's Avatar
agree with above
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 06-03-2010, 01:22 AM   #4
Beatcoaster
69 Fleetside
Beatcoaster's Avatar
Somebody got busy with the hole saw - mine doesn't have that...
1969 Chevy C10 Custom Camper - "Frame On" Restoration
Blueprint 383 w/ 405hp@5200rpm & 441ft-lbs@4200rpm / Jegs TH350 w/2300 Stall / Drivelines NW 2-Piece Shaft / stock 3.08's / CPP 4" Drop Rear, 3.5" Modular Drop Front
Beatcoaster is offline   Reply With Quote
Old 06-03-2010, 01:23 AM   #5
mstrav1973
mstrav1973's Avatar
good luck finding a plug for that. mine doesnt have that either and I have never seen one there.
Matt
72 chevy k-10, swb, auto, 35's, rally's, posi, 4" lift, 2.5" old style 40 series flows with headers and crossover pipe and some other stuff!!
mstrav1973 is offline   Reply With Quote
Old 06-03-2010, 02:04 AM   #6
FLEET72
FLEET72's Avatar
Mines got 2 holes there. Someone had put in an aftermarket A/C unit and that's where they routed the lines to the evaporator. I have aluminum tape covering the holes till I can get in there and weld a patch panel in...
Oscar
'72 Shortbed Fleetside
'95 Jimmy 4X4
'69 GMC Custom Camper
FLEET72 is offline   Reply With Quote
Old 06-03-2010, 02:30 AM   #7
72lb4x4
Try the home store hardware section with the drawers of strange stuff. I don't know if any are big enough, but there are round pop in sheet metal plugs that I've used to make some holes less obvious...
72lb4x4 is offline   Reply With Quote
Old 06-03-2010, 07:10 AM   #8
gkesseru
gkesseru's Avatar
If you want a quick fix, get a household door handle blank-off plate. Similarly, there is a round plastic plate available to protect your wall where door handles hit.
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
Old 06-03-2010, 08:26 AM   #9
Bullseye54
No hole there from factory.The auto paint supply shops around here have racks with misc trim parts on them with an assortment of plugs & such.An old style NAPA might be able to help,if you can find someone who can use a parts book.........................Bob
1967 C20 Custom - 396/TH400
1968 GMC short step-350/M21
Bullseye54 is offline   Reply With Quote
Old 06-03-2010, 10:30 AM   #10
FLEET72
FLEET72's Avatar
An electrical supply house will have what is called an "oil tight hole seal" http://www1.mscdirect.com/CGI/NNSRIT...59556&PMT4NO=0
looks like:
made from steel and can be painted to match.
Oscar
'95 Jimmy 4X4
Old 06-03-2010, 10:50 AM   #11
GOPAPA
GOPAPA's Avatar
looks like:
Exactly what I am going to do ..I remembered from my construction days seeing these in electrical panels . You beat me to it as I was going to go today and try and get one of these Fleet72 and show all what I came up with..thanks for the pictures .
Rather than burn up my new paint with a patch and weld this works just fine with me .
I will do my Vinegar trick to galv. on the engine side of the cover and then under coat it and paint it the truck color ..
It will be my conversational cover up story about my truck..LOL thanks again all of you for the replies..gp
Old 06-03-2010, 11:00 AM   #12
FLEET72
FLEET72's Avatar
The oiltite ones are painted so a quick light sanding and paint sticks quite well to them. I just filled a few holes in a control panel where knobs used to be. I had the local auto paint shop match the color and put it in aerosol cans, now I have touch up paint in a can for any work I have to do on the panel.
Oscar
'95 Jimmy 4X4
Old 06-03-2010, 12:06 PM   #13
GOPAPA
GOPAPA's Avatar
I will look for the painted ones ,thanks again buddy.. I too,,, have a couple aerosol cans of like my truck paint so I should be good to go .. the clutch linkage hole is a oblong hole so will have to do some cut and fit on that one ,,but a grinder will make it what ever I want .. Gp Larry
