Bed to Cab gap question
I am hopefully going to be shortening my frame soon for the short bed conversion on my 74 GMC.
And I was wondering if I could get the amount of gap on some of your trucks between the front of the bed and the rear of the cab? I would like to close up the gap some and figure if I can get a few measurements then maybe I could come up with an average that I could add to the 14" that comes out of the middle of the frame already. I figure on coming up with an average, because i'm sure that not all trucks are exactly the same.
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r http://67-72chevytrucks.com/vboard/s...d.php?t=460030 ![]() 97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver 220,000 miles, all stock for now |
Re: Bed to Cab gap question
I don't think it would matter if the measurements come from a lwb, swb, 2wd or 4wd.
Guess I could just shorten the frame down, put the bed where I want it then get the rearend centered afterwards.
GM Addicted
I seen at truck here in my town at dangerzone truck show. And instead of leaving the gap when he shorted his he made it like a unibody looked nice man. For an idea but that will be a high stress point.
![]() ![]() 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
That would probably be pretty cool, and alot of work to make it so you don't get any stress cracks.
I would like to close the gap by half of what the gap usually is or so, but i'm trying to figure out just how much that is. Anyone want to measure the gap between the rear of the cab and front of the bed for me?
#5 | |
Still plays with trucks
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
If you cut the frame BEHIND the front bed mounts, the gap won't change. But I think it's an inch or so like 68 TT said.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
I figured I would add in the amount that I want to close up the gap to the 14" that has to be taken out of the center of the frame anyway, pulling the bed and rearend forward to close the gap a bit and keep the rearend centered in the wheel wells.
When I shortened mine I set it at about 1.25" with the stepside bed. I believe it is closer to 1" now with the fleetside, but the front panel is bowed. If you want it correct you have to watch the wheelbase also which should come out to 131.5" if I remember right.
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ |
#10 | |
I would hate to see a crease in your cab from the bed rail contacting the cab under load.
Just actually measured it with the fleet bed. On the sides at the body line it is 1", at the top on the bed front panel it is 1.5"
Mine has been like this for about 6-7 yrs now and I have not had any issues with it. I already have a crease in the cab from when I got rearended when it was still a long bed. Heres how I did mine. I got the shortbed first, set it on the frame. The second set of holes from the tailgate matched up. I put bolts in there loosely to align it, then marked and cut the rear of the frame so it would sit flat. From there I went around measuring bed gaps on all kinds of different trucks and came up with 1 1/4 as what I wanted. I measured from the bed to the cab and came up with taking out the 14". I came 2" off the rear cab mount and made a mark. 14" from that mark I made another one. That was the section I cut out. I know I'm going to hear crap about this, but I made straight cuts and plated the inside of the frame after it was welded back together. I have had no issues with this and I still use it as a truck every once and a while. For a few years it was my only truck and I actually used it to move to AL, drove it down there full with all my tools and truck parts. It came back to SC behind the moving truck on a trailer, but the bed was full again. Oh and my wheelbase came out perfect at 131.5 too......
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ Last edited by bluex; 06-09-2010 at 02:44 PM. |
#12 | ||
#13 | |
It doesn't have to be fully welded in place either. Stitch welding by putting down a two inch weld and leaving an inch of open area before the next two inch long weld will cut down 33% of the welding work and minimally impact how strong the connection is. Alternate the open areas side to side on the flat bar so none of them line up across from each other. We do stitch welds all the time in structural frames and fabrication.
#14 | |
I haven't really ever thought about doing it like that, it's a good idea. I was just thinking about getting a large dimple die and some 3/16" plate, put a hole every 1-1 1/2" and basically box the frame in but not add as much weight. The way you described seems much easier and cheaper, as I wouldn't have to buy a die or as much steel.
#15 | |
In the case of our frame rails it is the top & bottom flanges of the frame rail that give it the most strength and is where we can increase the strength since we can't easily move the flanges further apart. Adding material to the top & bottom flanges of the frame rail will make a huge improvement in bending strength. If you add 3/16" flat bar it will pretty close to double the resistance to bending the frame has and greatly reduce the deflection when loaded. If you want additional torsional strength to help resist twisting then adding the box plate to the side of the frame rail will increase that.
#16 |
I was wrong on the wheel base. 131.5 is the LWB, SWB is 117.5, sorry its been about 6 years since I did it...
