Old 06-10-2010, 11:50 AM   #13
68 TT
Still plays with trucks
68 TT's Avatar
Re: Bed to Cab gap question
Originally Posted by Conundrum View Post
I have thought about that and plan to use the polyurethane body mounts to help thighten it a little more than the factory style rubber mounts would. I know it won't eliminate it but they should help, and I am also thinking of a way to try and stiffen the frame up a little without putting in a roll bar setup. And with it being a 2wd I plan for it to sit to low to really do any hauling other than maybe a cooler and lawn chairs, and i'm not to big on off roading.
You can really strengthen up the frame by adding a layer of 2"x3/16" steel flat bar to the top & bottom flanges of the stock frame rail. These are the areas that contribute the most to the bending strength of the stock frame.
It doesn't have to be fully welded in place either. Stitch welding by putting down a two inch weld and leaving an inch of open area before the next two inch long weld will cut down 33% of the welding work and minimally impact how strong the connection is. Alternate the open areas side to side on the flat bar so none of them line up across from each other. We do stitch welds all the time in structural frames and fabrication.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
