Old 06-20-2010, 09:42 PM   #1
entourageguy
Yellow truck club
entourageguy's Avatar
Bit of an interior change
Well my kids have been arguing about rides in Vanessa ( my daughter named her) and since I could only take two people I decided to change to a bench seat. I found one on Kijiji for $50 out of a 89 chevy 1/2 ton in good shape and started from there.
The orignal seats were ok but I thought I could brighten up the inside a bit.
My friend Jody at Kustomline Trim Designs did the work on the
seat side panels visors and ceiling change.
I removed all the old seat parts which included stacks of washers
and various plumbing parts to try to level out the seats. The drivers seat foam was
starting to break down and I was getting a numb leg after a short drive.
Name:  seat change 001.jpg
I put down some extra insulation as well as piece of carpet for behind
the seat.
Name:  seat change 003.jpg
I ordered seat belts from www.seatbelt planet.com in a yellow. This was a set
of three point retractables and a lap belt with the old style lift latches. I did not think it was
worth my while to run around the junk yard searching for a set.
The belts were $65 for the 3 points and $16 for the lap belt.
I made up a mount for the shoulder belt out of a piece of steel
with a nut welded to it. Also a hole was drilled for a rivet to hold it
in incase I wanted to remove it.
Name:  seat change 004.jpg
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 06-20-2010, 09:48 PM   #2
entourageguy
Yellow truck club
Re: Bit of an interior change
The truck feel different to drive even with the shoulder strap
sitting on your shoulder.The mount cover can be ordered in different colors
and I'm thinking about going to a tan carpet so I went with tan covers.
Name:  seat change 005.jpg
Seat in now waiting for the headliner and door panels.
Name:  seat change 010.jpg
Didn't take him long to get at the rest of my stuff.
Just a bit of change with the look of the inside don't you think?
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 06-20-2010, 10:29 PM   #3
blackdiesel
blackdiesel's Avatar
I like the change, real old skool. But the date on your camera?
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 06-20-2010, 10:47 PM   #4
shane o
Thumbs up Re: Bit of an interior change
very nice that is what I have in mind for my 47. Thank you for posting
shane o is offline   Reply With Quote
Old 06-20-2010, 11:09 PM   #5
Fat Mike
Fat Mike's Avatar
I see you have that same problem you told me about with your camera. Oh well, truck looks very nice.
Fat Mike is offline   Reply With Quote
Old 06-21-2010, 07:01 AM   #6
4DSEVEN
4DSEVEN's Avatar
Looks great!!
4DSEVEN is offline   Reply With Quote
Old 06-21-2010, 08:17 AM   #7
entourageguy
Yellow truck club
Back to the future ....... don't know what happened to the date thingy.
Gotta go back to work on the delorean
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 06-21-2010, 10:36 AM   #8
Kim57
Kim57's Avatar
Looks very nice.
Kim
Kim57 is offline   Reply With Quote
Old 06-21-2010, 06:38 PM   #9
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
That looks teriffic! Are you happy with the quality of the seat belts as far as fit and comfort?
Ryan
1969 Chevy milk truck
Old 06-21-2010, 08:02 PM   #10
entourageguy
Yellow truck club
I'm quite happy with the seat belts. I emailed back and forth a couple of times then called. Talked to Steve and placed my order. The color worked out great. It feels more secure driving with the shoulder belt on. I would recomend them.
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 06-21-2010, 09:54 PM   #11
tobins 52 gmc
tobins 52 gmc
Loving it very nice ,let me know where you will be for the next show and shine and i will try and hook up Robert
tobins 52 gmc is offline   Reply With Quote
Old 06-21-2010, 10:02 PM   #12
entourageguy
Yellow truck club
May try for Bradford Friday nite.
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 06-21-2010, 10:08 PM   #13
silversvs
Can you provide more detail on the 3 point belt and the mounting of the shoulder belt? There's more to it than the rivet I assume.
Current build http://67-72chevytrucks.com/vboard/s...=1#post3993829
'59 SB Fleetside sbc 350 Muncie M21 4 speed
silversvs is offline   Reply With Quote
Old 06-21-2010, 10:12 PM   #14
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Nice!!!!!!!!!
ChuckDriver is offline   Reply With Quote
Old 06-21-2010, 10:24 PM   #15
entourageguy
Yellow truck club
I made up a plate with a nut welded to it. I located the spot I wanted the shoulder mount to be then drilled a hole for the bolt. I threaded the bolt into the bracket and put it in the hole drilled. I used the hole I drilled for the rivet as a pilot hole and drilled into the inner panel to locate the rivet. I used a piece of coat hanger and taped the bracket to it. Fished the bracket up and used the main mounting bolt to draw the bracket tight. I then used the pin end of the rivet to move the bracket so I could rivet the bracket inside the panel. Now I can remove the main bolt and the rivet will hold it in place.
Here a link for more info. Sort of how I did it.
http://www.bobshotrods.com/howto/3-p...chevy-pick-up/
Setbelt are from here
www.seatbeltplanet.com
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 06-21-2010, 11:06 PM   #16
Atomsplitter
Atomsplitter's Avatar
Here's Juliano's instruction's for a 47-55 5 Window
http://www.julianos.com/how2_3point_...evy_truck.html
Atomsplitter is offline   Reply With Quote
Old 06-22-2010, 02:47 AM   #17
MrSinister
MrSinister's Avatar
Looks awesome. Thanks for posting the link, seatbelts are one of the next things I need
'56 Big window
350/700r4
9" rear w/disc
MrSinister is offline   Reply With Quote
Old 06-22-2010, 02:52 PM   #18
Dieselwrencher
Thanks for the info. I'm thinking of adding seat belts to my 40 in the next year or when ever.
Ryan
