06-25-2010, 12:00 PM | #1 |
donor frame?
has anyone used or has seen a frame from an astro van from the mid 90s under a 1951 ad swb 1/2 ton? if not would the rear end work? any input would be great.
06-25-2010, 12:30 PM | #2 |
Re: donor frame?
I believe an Astro uses a unibody design.
IF A FELLA DOESN'T USE HIS HEAD....... HE MIGHT AS WELL HAVE TWO BUTTS 1969 C10 LWB "Granpaps Truck" (Project) 2000 K3500 Crew Cab LWB (Farm Truck) 2007 Chevy 1500 Crew Cab 5.3 (Daily Driver) |
06-25-2010, 01:20 PM | #3 |
Re: donor frame?
Astro vans have a sub-frame. Also the lower control arms are "bent", so the track width will fit under the fenders.
The subframe is pretty wide, and stubby near the engine. Only good for an Astro van. And lowering parts (spindles) aer getting harder to find. The rearend is the same 10 bolt design as a truck but the center section is offset to the right to clear the Astro's gas tank.
88 Chevy C1500, step side, LS swap. 98 Crew Cab Dually, tow rig. 03 Dodge Neon. ECTA Ohio Mile record holder. Last edited by MotorHead Lon; 06-25-2010 at 01:21 PM. |
06-25-2010, 01:50 PM | #4 |
Re: donor frame?
ok the astros out-- thanks.... i have a 1994 vette front end i was looking into the flatout engineering setup. has anyone here used it or has used the stock crossmember.... one more where are you guys getting your drive shafts done i cant find any local shops that cut them or even make them. thanks
06-25-2010, 11:14 PM | #5 |
Re: donor frame?
The Flatout setup has a pretty good reputation if you want to go that way.
As far as driveshafts http://www.google.com/search?source=...=&oq=&gs_rfai= If that doesn't suit you http://www.iedls.com/ in California. They will UPS a driveshaft anywhere. Last edited by mr48chev; 06-25-2010 at 11:16 PM. |
06-27-2010, 12:44 PM | #6 |
Re: donor frame?
i've talked to the guys from flat-out there great. i was thinking of the stock crossmember its a pretty beefy unit and was a bolt in on the vette. i was looking for pics if anyone has done it before.
