Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > Welcome Area
Old 06-28-2010, 12:58 PM   #1
MotiV-8r
Unhappy EZ Wiring , how easy?
Finished body work/primer, dropped in engine/trans (both rebuilt) finally feeling confident on progress , removed dash cluster only to find a _rapy wire harness
install! (Ms.Smith 1st.grade class work) Another mountain- advice & help appreciated
MotiV-8r is offline   Reply With Quote
Old 06-28-2010, 05:48 PM   #2
scotts62
One day...
scotts62's Avatar
Re: EZ Wiring , how easy?
Welcome from OKC! They are not too bad just take your time and route them where you want them before you cut.
Scott
93 crew cab build
Project 62
Old 06-28-2010, 06:40 PM   #3
Bpokey
Bpokey's Avatar
Used E-Z wiring on mine and it wasn't too bad. Wires are labeled well but you will have to solder on some terminals. I had to engineer a way for the wires to go through the cab because there is no bulkhead connector. I haven't had any problems since I put it in though.
Bpokey is offline   Reply With Quote
