Old 07-05-2010, 12:57 PM   #1
SanitysBane
Front Bench Seat?
Hey guys,
Did Blazers or Suburbans come form the factory with front bench seats?
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 07-05-2010, 03:03 PM   #2
Skratch
Skratch's Avatar
Re: Front Bench Seat?
Don't know about Blazers, but Burbs did . . . I had one in both of mine, still have one in the 2wd but the 4wd got converted to buckets and a stock console instead.
If it ain't broke, then I haven't fixed it yet!
'86 Fiero SE 2M6 (undergoing a Northstar swap)
'87 1/2t 4wd Suburban (4" lift with built 1t axles and beadlocks)
'90 3/4t 2wd Suburban (Tow Rig)
'94 3/4t 4wd G20 Van (Toasted tranny and rusted)
'96 Deville
Skratch is offline   Reply With Quote
Old 10-13-2010, 10:28 PM   #3
iluvmy72
I know this thread is a few months old....but how did you do this?
iluvmy72 is offline   Reply With Quote
Old 07-05-2010, 03:40 PM   #4
SanitysBane
So a front bench from a Burb should bolt in?
'88 K5 Blazer
Old 07-05-2010, 03:48 PM   #5
RandyP
Getting Old; Going Broke
RandyP's Avatar
Bench seats in suburbans do not pivot/fold forward. So if you put one in a blazer, you can not get in the back seat, if you put one in a pickup you can not access your rear cargo shelf area.
RandyP is offline   Reply With Quote
Old 07-06-2010, 08:35 PM   #6
SanitysBane
So I need to put one from a truck in there? How much fab work will that entail?
'88 K5 Blazer
Old 07-07-2010, 12:31 PM   #7
Jonboy
Slots go on anything!
The floor is completely different, if you are wanting to put a bench in your Blazer. Look at a bench from a 88-98 ext. cab pickup to go into a Blazer. You will need to reinforce the floor a bit, and use grade 8 mounting hardware.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
