Old 07-25-2010, 06:04 PM   #1
72TXSuperCheyenne
72TXSuperCheyenne's Avatar
cheyenne-10 & super emblem location
I am wondering the proper alignment of the "super" in relation to the cheyenne-10 logo on the drivers side fender?
All the "restored trucks" have the super under the cheyenne on both sides.
However, i have original 72 drivers side fender (without any bades) with the holes drilled and it would allow for placement for the right side of "super" emblem flush with the right side of the "10".
Does anyone know for certain?
thanks
Jeff
72TXSuperCheyenne is offline   Reply With Quote
Old 07-25-2010, 10:01 PM   #2
71 super
71 super's Avatar
Re: cheyenne-10 & super emblem location
The super always lines with the "c" in cheyenne. Lots of psuedo supers are lined up on the 10 side and it is a dead give away to a truck that has had emblems added.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 07-26-2010, 12:12 AM   #3
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Harold is spot on, as the Super should start below the Cheyenne on both sides. Awhile back I made a drawing of my fenders, as it should be real close to accurate. Sometimes my eyes get the better of me on measuring. Trevor
Sorry if it doesn't show up that great, I made it to help out Rob on his Superburb, but my cpu crashed and this is the biggest version I have saved.
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 07-26-2010, 02:21 PM   #4
72TXSuperCheyenne
Thanks Guys! I am thinking that fender is from a Custom/10 which had the deluxe set flush to the right on driver's side.
Old 07-26-2010, 03:47 PM   #5
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Thanks for that guide Trevor!
Ryan
1969 Chevy milk truck
Old 01-04-2012, 12:49 AM   #6
jocko
jocko's Avatar
Ok, I know this is an oooollldddd thread, BUT, if the alignment of the "Super" is supposed to be "S" in super aligned under the "C" in cheyenne, then why are there SOoooo many out there that are done "incorrectly"? Ok, harsh word, what I mean is - "other than originally done by Mr. Chevrolet?" I mean -if you're gonna restore an original "super" then the holes are already in the right place - if you're gonna build a clone, why go to so much effort in the restoration and then drill the dang holes in the wrong place? Hmmm.
And I won't even go into the vertical spacing between the two....
Now, for me, I agree with the above statement that the Super is always aligned with the Cheyenne (i.e. "left justified" as you look at the emblems - from either side of the truck).
And based on looking at the original 72 sales brochure, I'm assuming the exact same logic applies to the Custom Deluxe emblems (i.e. I think post #4 is incorrect (?)).
Can someone put my mind at ease and settle this once and for all? - I'm actually losing sleep over this! (ok, that's an exaggeration, only for effect....)
Old 01-04-2012, 05:21 PM   #7
Dieselwrencher
It they're in the wrong spot than either the truck is a Super clone, or maybe the fenders were replaced and whom ever did it installed the emblem in the wrong spot.
Ryan
Old 01-04-2012, 05:59 PM   #8
71 super
71 super's Avatar
Not everyone pays attention nor has access to a build manual etc. If you look at a lot of the clones there are always missing pieces, tailgate handles being a huge one. All supers got a bright tailgate handle (if a fleetside), in 71 the actual handle was chromed, in 72 it was a slip on cover over the stock handle. These are very hard to find and only one person repops them (wes at classic heartbeat). It is funny that most of these clone trucks also ironically are missing the SPID on the glove box door as well. The headliner and cargo light are also indicators but can be faked and tough to tell unless you take out the liner or at least remove the trim- people snap off the tabs that locate it on the cab and just use the screws, and I would guess the cargo light interior holes are difficult to duplicate. These are just a few things that are give aways, but you have to look.
Old 01-04-2012, 08:42 PM   #9
sameyrasmea72
sameyrasmea72's Avatar
There is another problem you see pretty often, where it is correct on one side and incorrect on the other side. This could easily be done on new fenders where you use a pattern to drill the holes. This is done when people drill one fender and Flip the pattern instead of transposing it to the other fender.
This truck may not be a real super (wrong paint and no upper trim) but it is a good example of the flipped pattern.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 01-04-2012, 09:50 PM   #10
jocko
jocko's Avatar
YES - this is how I normally see it (when it's done incorrectly). Beautiful truck though!
Old 01-05-2012, 01:56 PM   #11
100gold
This thread makes me want to throw up. I used some fenders off of a 70 custom and never paid one bit of attention to this detail when I put my emblems back on. Argh!
100gold is offline   Reply With Quote
Old 09-23-2014, 09:08 AM   #12
j carter
Is this information in a assembly manual?
j carter is offline   Reply With Quote
Old 09-23-2014, 12:11 PM   #13
Bill Beasley
Original truck...
72 Super LWB
Bill Beasley is offline   Reply With Quote
Old 09-23-2014, 12:15 PM   #14
j carter
I is it anything that tells you the measurements on where the emblems go if u get new fenders
Old 09-23-2014, 01:22 PM   #15
5025speed
Can anyone tell me why the C20 big block Cheyenne Supers are easier to find than the C10 big blck supers? Thanks
5025speed is offline   Reply With Quote
Old 09-23-2014, 03:53 PM   #16
71blksuper4x4
SWB 4x4 Collector
Most 3/4 tons were made to tow or do heaving lifting where as a half ton would have been more for the experience. Even today, Diesels (kind of the same as the old big blocks) are the grunt pullers on 3/4 and 1 tons, but you cannot get one in a 1/2 ton. Depends on the duties you need, and most trucks back then were just that, Trucks. If you wanted a sporty powerful toy, you bought muscle cars then. Trevor
TREVOR
Old 09-26-2014, 01:36 AM   #17
68 50th
68 50th's Avatar
Havenīt noticed this before. When I restored my 71 Super I changed the left side front fender to a nice used one. It alreday had the emblem holes in it so I just used them
Now I can see the location is not correct for the left side but it is correct for the right side. Looking at old pics from before resto it was correct on the old (original?) left fender
Hereīs a pic from the assembly manual that shows the Super emblem location;
Mats..
1971 Cheyenne Super Custom Camper 475CBB/TH400/AC
1992 Silverado Sport Truck
1988 Silverado 2500 Ext Longbed 4x4
2001 GMC Sierra SLT 4x4
1990 Chevrolet K3500
1965 Pontiac Grand Prix
1980 Z 28 350/4-speed/AC/T-top
1980 Camaro Coupe V6/3-speed
1979 Buick Century Wagon
68 50th is offline   Reply With Quote
Old 09-26-2014, 06:35 AM   #18
j carter
Thabks
Old 08-05-2018, 05:42 PM   #19
knomadd
knomadd's Avatar
I hate to bring up an old thread, but I'm trying to install custom emblems in the factory location. They're billet and don't have holes in the factory location, so I can't use a factory holes to make it work. Plus, I really don't want to drill holes in my fenders that aren't the same as a factory emblem.
Can someone with a Cheyenne take measurements from the edge of the emblem to a good reference, like the back of the fender and possibly the body line above the lower trim, or the top of the fender (with a soft measuring tape)?
I tried to recreate the emblem location based on measurements of an original Cheyenne emblem and the above referenced info and came up with about 3-3/4" from the rear edge of the fender to the emblem and 7-3/4" from the body line to the bottom of the emblem. It just looks too low and too far forward to me, but I don't have one nearby to compare with.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 08-06-2018, 02:36 PM   #20
knomadd
knomadd's Avatar
I got a few photos of the Cheyenne emblems that might help a few members in the future. Thanks to Lolife99 (Keith) for the emblem stud measurements, and this page, I was able to get the emblem located, but looking at it, I was concerned it might be too far forward. Thanks to Chris on the 67-72chevytrucks.com Facebook page for the emblem on fender measurements. I was able to confirm what I had before mounting the emblems. Here are some pictures for reference.
-Duane
Old 07-03-2020, 10:46 PM   #21
General23cmp
So I wanted to revive this older thread as I had a few questions.
1. Does anyone have official drawings that shows the Cheyenne emblem placement. The drawing above when compared to the measuring tape photos after it, are not the same (not really close). The distance from the edge using measuring tape shows ~4-9/16 to the pin hole, but the homemade drawing shows 4-9/32”. I realize these were installed by hand, and thus differences, but this is a difference of over 1/4” and I wonder what the true drawing says.
2. Can anyone check/verify that the pins on both sides of the Cheyenne 10 emblem are the same distance away from their closest edge of the emblem? It doesn’t look like it on the measuring tape photos, but it could just be the angle. You really need them to be the same if you want the emblem to be in the same spot from one side of truck to the other (using the same dimensions to drill your holes).
Thanks.
General23cmp is offline   Reply With Quote
Old 07-05-2020, 02:23 AM   #22
Richard
Post #17 is from the factory assembly manual. Unfortunately it does not show dimensions from and edge as most of the drawings. Some drawings in the manual reference a point. That drawing does not. Regardless, I have not figured out how to determine where the reference point is located. Have a set of nos Cheyenne 10 emblems I can reference to my nos Custom 10 emblems and then measure the holes in my fenders next week.
Richard
Old 08-15-2023, 10:05 PM   #23
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Originally Posted by pjmoreland View Post
According the factory assembly manual, the left hole for the SUPER emblem is 1.09" directly below the left hole for the Cheyenne emblem. The right hole for the SUPER emblem is 4.15" directly to the right of the left SUPER hole. I drilled mine this way and it looks just like the picture Castiron9 posted. Also the left edges of the Cheyenne and the SUPER emblems are even with each other on both sides of the truck, so on the passenger side, the SUPER emblem is closer to the back of the truck and on the driver side, the super emblem is closer to the front of the truck.
In another older thread pjmoreland said the above - I been looking for this information too and thought I'd post it here and some additional stuff
This is from page 1013 of the Chevy Factory Assembly book - which you need the spread sheet to find anything (even then it hard due to no page numbers). Anyways, odd that it doesn't have a page to show how to center it on the fender - say if you are need to make holes for the Cheyenne 10 badge.
Edit:
rats, can't attach the "assembly manual index.xlsx" sheet
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
Old 08-15-2023, 11:27 PM   #24
pjmoreland
pjmoreland's Avatar
I believe the holes for the larger emblem were drilled when the fender was manufactured. I bought a NOS fender a number of years ago, and that's how it came. You'll probably need to remove your Cheyenne emblems so that you can measure the SUPER emblem hole locations relative to the existing holes.
There's a photo of a NOS fender in this thread.
http://67-72chevytrucks.com/vboard/s...ght=Nos+fender
pjmoreland is offline   Reply With Quote
Old 08-16-2023, 07:17 AM   #25
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Ah, that's very interesting - how lucky to find a NOS fender!
I agree, fender comes off to get it right.
Richard
