HO110 has been found
Hi everybody, Ive been away from the forum for some time sled pulling.
I scored a real 1947 GM HO110, its in the driveway. It's an odd one with 10 bolt hubs, a flange type axle shaft like a modern pickup truck, a pickup sized hub where it goes through the wheel, and a bolt on rear cover. It's housing is 18" tall or so at the center, it would take 3-4 burly guys to pick it up. 750 LBS easy. It's so massive compared to the HO72, I think people will need pictures just to understand. The HO72 is one strong axle but this is comparable to the rockwell 106 all around. We actually compared it to the 106 as the guy I bought the 110 from had a 106 right there. This is a beast of an axle for sled pulling. The ring gear OD is 12.25", the third member weighs 150ish LBS 6.17 ratio, 1 5/8" axle shafts. Does anyone know of some old pullers who may know which Eaton axle gears may fit? The DS34, DS38, AND S130 ring gears look very very similar. The S130 has a 12.2" published ring gear OD. I would like it to be 4.88 ratio, not one used by GM.
86 Chevy K30 Crew Cab, USAF(retired), TH400/NP205, 28K miles 99 Chevy (88-98 Style) Reg Cab LS, K2500 454, nv4500 92 Dodge, Cummins, SLED PULLER, 5'' hood exit, NV4500UHD, dual disk clutch, Borg Warner S400 charger, GM 7200#/14B hybrid rear Dads... 69 GMC k2500, 427, 4 speed, Rockwell 221, 7200# rear, detroit, disk brake front, 5.13's |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: HO110 has been found
Someone needs to do this
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
http://www.pirate4x4.com/forum/showt...ghlight=ho+110
Some good info there. And if anyone in NE area is looking for a few of these I know guy that has 3-4 in his yard. Jason.
PM me if you have any HO52 or HO72 5.14 gears for sale or I could trade you a set of 4.10. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() A few pics of the dana 44HD rotors on the hubs ![]() ![]()
#6 | |
NE meaning northeast or Nebraska? I could use some parts for this one. The axle nuts were thrashed, I had to turn them out by hammer/chisel. I might be able to fix the diff cover but a good straight one would be nice or one from a duece Here is what I know about the H110... Its not the biggest axle in the GM "H" series, there is an H135 and an H150 that I remember. The H110 is in the grey area of axles the ring gear is bigger than the rockwell 106, the axle shafts are basicly the same size, Yet it was available in a one ton pickup! A Dana 80 37 spline inspired axle should fit the spindle if the side gears could be reworked. Production was from 46-81 (that I can verify) the rockwell (106?) takes its place in 82 on the step vans 10 and 6 lug hubs were available Some had splined flange end axles, others were typical bolt on earlier models had bolt on sheet metal rear covers, except for the M135/M211duece which had a beefy cast iron ribbed front cover (the only way to make it cooler would have been to cast THIS SIDE TOWARD ENEMY ![]() Two gear ratios, 6.17 and 5.43 (not so common) Gears might interchange from an eaton axle which would make for a nice gear spread Used in one ton pickups with DRW and optional 11,000 GVW up till 1968 Used in the GMC M135, M211 Duece and a half (front and rear). I am real curious about the shaft joint design used on the steer axles in those dueces. There are closed knuckle. Used in step van (king?) 11,000 GVW up till 1982 (these had bendix disk brakes very similar to a dana 60 front) It appears they were used in 40-60 series trucks as well
86 Chevy K30 Crew Cab, USAF(retired), TH400/NP205, 28K miles 99 Chevy (88-98 Style) Reg Cab LS, K2500 454, nv4500 92 Dodge, Cummins, SLED PULLER, 5'' hood exit, NV4500UHD, dual disk clutch, Borg Warner S400 charger, GM 7200#/14B hybrid rear Dads... 69 GMC k2500, 427, 4 speed, Rockwell 221, 7200# rear, detroit, disk brake front, 5.13's Last edited by stillsmokin; 10-08-2010 at 01:12 AM. |
NE, NewEngland area so yes the northest.
I cant confirm one since I ve only seen them and never taken one a part but according to that Pirate link 5.13's were offerd. http://www.pirate4x4.com/forum/showp...4&postcount=20 If you look at the last Pic in that post it shows the number 7-36 stamped into the 3rd memeber head. So if its anything like its smaller brother axle's the HO52/72 then it should be stamped, the gear ratio. http://www.pirate4x4.com/forum/showp...&postcount=135 That other one was a post int he HO72 thread on Pirate and it shows the only one gear option for the 110. Off topic but it does show a 5.83 axle ratio for a HO72, I would love to find a set of them ![]() Jason.
[QUOTE=Jason M;422977[url]http://www.pirate4x4.com/forum/showthread.php?t=850670&highlight=ho+110[/url]
Some good info there. And if anyone in NE area is looking for a few of these I know guy that has 3-4 in his yard. Hi...to all interested I believe I have a HO72 in my 69 c-30 and it has 6.17 gears..I'm looking to change these out , maybe for 4.10 or something |
I have a HO72 center with 4:56 gears. You can have it if you can get it from NM
Leon '68 K20 fleetside, 400sb/sm465/np205, 4" lift, 32" tires. |
EDIT: It is actually an H110
Sorry, I'll try to get some pics up later today. I did get the oem 15-18" drum brakes pulled off of it, the original owner fiddled with them for years trying to get them off. I really dont have a choice but to put disk brakes on the hubs and make it 8 lug. Anybody ever see an 8 lug on 6.5" bolt circle disk rotor with a 5.5" center hole? They don't have to be from a GM application. I have some 72-76 dana 44 rotors here, the center hole is bigger than the newer style rotors but still only 5 inch or so. My oh my how big the parts in this thing are, and where is the offroad aftermarket... C L U E L E S S
86 Chevy K30 Crew Cab, USAF(retired), TH400/NP205, 28K miles 99 Chevy (88-98 Style) Reg Cab LS, K2500 454, nv4500 92 Dodge, Cummins, SLED PULLER, 5'' hood exit, NV4500UHD, dual disk clutch, Borg Warner S400 charger, GM 7200#/14B hybrid rear Dads... 69 GMC k2500, 427, 4 speed, Rockwell 221, 7200# rear, detroit, disk brake front, 5.13's Last edited by stillsmokin; 10-07-2010 at 01:27 PM. |
