20' Daredevil (Ret)
![]() Join Date: May 2003
Re: HO110 has been found
Someone needs to do this
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
http://www.pirate4x4.com/forum/showt...ghlight=ho+110
Some good info there. And if anyone in NE area is looking for a few of these I know guy that has 3-4 in his yard. Jason.
PM me if you have any HO52 or HO72 5.14 gears for sale or I could trade you a set of 4.10. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() A few pics of the dana 44HD rotors on the hubs ![]() ![]()
86 Chevy K30 Crew Cab, USAF(retired), TH400/NP205, 28K miles 99 Chevy (88-98 Style) Reg Cab LS, K2500 454, nv4500 92 Dodge, Cummins, SLED PULLER, 5'' hood exit, NV4500UHD, dual disk clutch, Borg Warner S400 charger, GM 7200#/14B hybrid rear Dads... 69 GMC k2500, 427, 4 speed, Rockwell 221, 7200# rear, detroit, disk brake front, 5.13's |
#5 | |
NE meaning northeast or Nebraska? I could use some parts for this one. The axle nuts were thrashed, I had to turn them out by hammer/chisel. I might be able to fix the diff cover but a good straight one would be nice or one from a duece Here is what I know about the H110... Its not the biggest axle in the GM "H" series, there is an H135 and an H150 that I remember. The H110 is in the grey area of axles the ring gear is bigger than the rockwell 106, the axle shafts are basicly the same size, Yet it was available in a one ton pickup! A Dana 80 37 spline inspired axle should fit the spindle if the side gears could be reworked. Production was from 46-81 (that I can verify) the rockwell (106?) takes its place in 82 on the step vans 10 and 6 lug hubs were available Some had splined flange end axles, others were typical bolt on earlier models had bolt on sheet metal rear covers, except for the M135/M211duece which had a beefy cast iron ribbed front cover (the only way to make it cooler would have been to cast THIS SIDE TOWARD ENEMY ![]() Two gear ratios, 6.17 and 5.43 (not so common) Gears might interchange from an eaton axle which would make for a nice gear spread Used in one ton pickups with DRW and optional 11,000 GVW up till 1968 Used in the GMC M135, M211 Duece and a half (front and rear). I am real curious about the shaft joint design used on the steer axles in those dueces. There are closed knuckle. Used in step van (king?) 11,000 GVW up till 1982 (these had bendix disk brakes very similar to a dana 60 front) It appears they were used in 40-60 series trucks as well
86 Chevy K30 Crew Cab, USAF(retired), TH400/NP205, 28K miles 99 Chevy (88-98 Style) Reg Cab LS, K2500 454, nv4500 92 Dodge, Cummins, SLED PULLER, 5'' hood exit, NV4500UHD, dual disk clutch, Borg Warner S400 charger, GM 7200#/14B hybrid rear Dads... 69 GMC k2500, 427, 4 speed, Rockwell 221, 7200# rear, detroit, disk brake front, 5.13's Last edited by stillsmokin; 10-08-2010 at 01:12 AM. |
NE, NewEngland area so yes the northest.
I cant confirm one since I ve only seen them and never taken one a part but according to that Pirate link 5.13's were offerd. http://www.pirate4x4.com/forum/showp...4&postcount=20 If you look at the last Pic in that post it shows the number 7-36 stamped into the 3rd memeber head. So if its anything like its smaller brother axle's the HO52/72 then it should be stamped, the gear ratio. http://www.pirate4x4.com/forum/showp...&postcount=135 That other one was a post int he HO72 thread on Pirate and it shows the only one gear option for the 110. Off topic but it does show a 5.83 axle ratio for a HO72, I would love to find a set of them ![]() Jason.
#7 | |
5.13's were an HO72 ratio, it would be nice if the aftermarket stepped up and made them for the H110 though. GM offered 2 ratios for the H110 (to partially credit the guys over on pirate), most axles will have 6.17's. However, some of the later axles (1980's era) had 5.43's (and disk brakes). GM lists a ring and pinion that ratio for 1982 P30. There is a guy not too far into Missouri with a 70's dodge power wagon (440 stage 5 hemi) that runs an H110 in the rear with 5.43's. He said it leaked the oil out over one winter in storage and chewed up some parts running oiless the next season. He claims to had a heck of a time finding another 5.43 third member. The last HO72 ratio is a super oddball one year only deal ('63, something about a 3 speed manual with C30, if I remember right) the ratio is actually 5.38. Never seen a set yet. One thing is certain, right now the HO72 and H110 are virtually unknown outside GM circles. They are proving themselves in competition applications and rapidly gaining popularity.
86 Chevy K30 Crew Cab, USAF(retired), TH400/NP205, 28K miles 99 Chevy (88-98 Style) Reg Cab LS, K2500 454, nv4500 92 Dodge, Cummins, SLED PULLER, 5'' hood exit, NV4500UHD, dual disk clutch, Borg Warner S400 charger, GM 7200#/14B hybrid rear Dads... 69 GMC k2500, 427, 4 speed, Rockwell 221, 7200# rear, detroit, disk brake front, 5.13's Last edited by stillsmokin; 10-12-2010 at 12:40 AM. |
#8 | |
I know they are out there that link show's them in service. The only reasion I belived they were 5.13 for the 110 axle was there was a letter code stamped into the 3rd on that other link from Pirate. It was the same number code I see on the HO52/72 3rds and this one was 7-36 witch is the code used for the 5.13 ( well GM calls it a 5.14 ). I agree I allways take internet info with a grain of salt, I like to see first hand then I can say for sure. Jason.
[QUOTE=Jason M;422977[url]http://www.pirate4x4.com/forum/showthread.php?t=850670&highlight=ho+110[/url]
Some good info there. And if anyone in NE area is looking for a few of these I know guy that has 3-4 in his yard. Hi...to all interested I believe I have a HO72 in my 69 c-30 and it has 6.17 gears..I'm looking to change these out , maybe for 4.10 or something |
I have a HO72 center with 4:56 gears. You can have it if you can get it from NM
Leon '68 K20 fleetside, 400sb/sm465/np205, 4" lift, 32" tires. |
