Old 10-22-2010, 01:00 AM   #1
Slick67
Sofa King Crazy!!
Slick67's Avatar
Brake lines not gettin the juice.....
Cannot get the fluid to go to the back brakes. Typical disc/drum setup. I did have the rear line higher than the prop valve but fixed that. Air is coming out the rear bleeders when the pedal is compressed but no fluid. I bench bled the master cyl. All new lines, no crimps in the lines and all seems right. Any thoughts??
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 10-22-2010, 09:13 AM   #2
cdowns
cdowns's Avatar
Re: Brake lines not gettin the juice.....
lots of guys neglect clamping the pin on the combination valves as instructions in the factory service manual states as the proper way to bleed these brakes
Old 10-22-2010, 11:43 AM   #3
Slick67
Sofa King Crazy!!
Slick67's Avatar
Clamping the pin? Is that the pin on the back of the prop valve? My rear brake hose comes out toward the front of the truck, and there is a pin on the back.
Old 10-22-2010, 01:08 PM   #4
68gmsee
Active Member
68gmsee's Avatar
If you're postively sure that you're not sucking in air from somwhere like a loose connection or crack in the brake lines or rubber hoses (two in front, one in rear) then it could be just a lot of air in the lines. Be sure and not let the master cylinder get low on fluid when bleeding. I usually add fluid over 2 full depressions of the brake pedal.
Also you can loosen the fittings at the master cylinder and work yourself back to see if you can isolate it.
68gmsee is offline   Reply With Quote
Old 10-22-2010, 02:11 PM   #5
Myself
I had that exact same problem on one earlier this summer. The safety valve in the proportioning block will switch to one side if there is a problem with front OR rear. I ended up having to just really smash the pedal while my wife tapped on the prop block with a hammer. After a bit we heard a popping noise and pressure was restored to the rear. This was all due to a leaking brake line to the rear.
Myself is offline   Reply With Quote
Old 10-22-2010, 03:05 PM   #6
mrein3
mrein3's Avatar
I believe that holding that pin in overrides the safety feature that diverts fluid away from a failed half of the brake system. You may have the tripped this system and will need to make the tool the service manual describes to hold the pin to get your brakes bled.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 10-22-2010, 10:18 PM   #7
Slick67
Sofa King Crazy!!
Slick67's Avatar
Alright! Some great suggestions here! My girlfriend watched the thread for me today and called me with updates, what a chick. First issue I discovered was that the lines were backwards from the MC to the Prop valve (see above pic). Also had a couple of connections that were not sealed well. Got all of these problems fixed and bled the system. Had brakes for a little while then they faded. The pedal is still bottoming out and I can't get the front passenger side to bleed out properly. More suggestions???
Old 10-22-2010, 11:11 PM   #8
PHAT TONY
PHAT TONY's Avatar
I've had to put a cheapy hand vacuum pump with a hose on the rear lines to the wheel cylinder at the wheel cylinder and draw fluid to the back, and yes; it may empty the master.
1972 factory 2 Wheel Drive Blazer-Sold
1972 K10 4X4-Sold
1971 Chevrolet Cheyenne/10-Sold
1970 Chevrolet C/10-Sold
1968 GMC 4X4-Project
1968 Chevrolet C/10 Pro Street
1970 GMC 3/4 Ton-Parts
1997 2WD 2DR Yukon-Sweet
http://67-72chevytrucks.com/vboard/s...d.php?t=335664
PHAT TONY is offline   Reply With Quote
Old 10-23-2010, 09:54 AM   #9
Slick67
Sofa King Crazy!!
Slick67's Avatar
Tried a vacuum yesterday with little success. Finally got some fluid to run through every line, but not a steady stream. I had the front working and before I left the shop it had no front brakes. The back brakes never did work. All of the lines have been seperated at the connectors and new teflon tape put on. Back to square one? Is there something that I am missing?
Old 10-23-2010, 10:09 AM   #10
mrein3
mrein3's Avatar
No tape on flare fittings! Did you try holding that pin while bleeding?
'72 Malibu hard top
Center City, MN
Old 10-23-2010, 10:20 AM   #11
Slick67
Sofa King Crazy!!
Slick67's Avatar
Originally Posted by truckdude239 View Post
stop why did you put teflon tape on the fittings???? the brake lines a re flare fitting that are self sealing. if you put teflon tape on the fitting they will elak and not seal correctly. i'd pull the fittings and remove all the teflon tape and tighten everything back up and go from there
I did use teflon tape but just one round and only on the threads at the top of each connection. There is no teflon tape close to the end of the threads at the flared end. Is that still a no-no to do that?
Old 10-23-2010, 03:02 PM   #12
Slick67
Sofa King Crazy!!
Slick67's Avatar
The pin that is on the prop valve needs to be pushed in while bleeding but is it free floating or does the hex head around it need to be loosened?
Old 10-23-2010, 10:11 AM   #13
pat 70/71
pat 70/71's Avatar
shouldn't need teflon tape anywhere in a brake system. (flare fittings) Did you change out all the front hoses? old ones can get blocked over time. re bleed the master& open up one wheel cylinder at a time starting @ pass rear & push new fluid shouldn't take too long . could master be bad? hope this helps. cheers, Pat
pat 70/71 is offline   Reply With Quote
Old 10-23-2010, 10:04 AM   #14
truckdude239
truckdude239's Avatar
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 10-25-2010, 11:19 PM   #15
VA72C10
VA72C10
VA72C10's Avatar
bump for answers because I don't have any
Old 10-26-2010, 07:38 AM   #16
mrein3
mrein3's Avatar
I have seen cases where the "check ball" piece in the proportioning valve got stuck. This is evident by the brake light getting stuck on. With the pin clamped and enough bleeding and some gentle taps on the valve I was able to center it again.
Is your brake light on? Does the brake light work?
Are your back brakes adjusted properly? The shoes should slightly drag with no pressure on the brake pedal. With the rear tires in the air I like to adjust the rears until there is some resistance in the spinning wheel.
Have your girlfriend get in the driver's seat and push HARD with both feet on the brake pedal while you run around and look at EVERY connection for leaks.
That is all I can think of right now.
'72 Malibu hard top
Center City, MN
Old 10-26-2010, 09:10 AM   #17
Slick67
Sofa King Crazy!!
Slick67's Avatar
I will check the brake lights. The rear drums are easy to spin but they do have a little friction. I can adjust those a little tighter I think and will do that today. There are no leaks at all, I have checked this over and over. The check vavle sounds like a reasonable problem since I had brakes on the front, then they faded. Well....off to the shop for another round with "sancha". Thanks for the bump VA and mrein3 for all of the great help, I appreciate your patience and keeping up with this thread. Once it is fixed I will post the answer to the problem.
Old 10-26-2010, 12:42 PM   #18
mrein3
mrein3's Avatar
Sorry I wasn't more clear. Make sure the brake warning light in your dash works and is not on. If the bulb is burnt out you may not know if your prop valve is stuck to one side. I believe that when you turn ignition key on it should light up. Then ground the wire on the prop valve and confirm that this lights that lamp.
'72 Malibu hard top
Center City, MN
Old 10-26-2010, 09:07 AM   #19
stich626
if you have a pedal than it's gone, you have a leak somewhere, thats allowing air back in..
is there any cracks in the flares?
if you made lines you did double flare..
you did use copper washers at the front disc calp to rubber line bolt..
the master could be sucking in air.. you blead the master , and plug the ports with plugs ( they make flare nuts with no hole for the line, (or make two)
got a pedal, good walk away.. in an hour does it?
if so the master fine..
next,, sounds line you have a crushed line,, that slowly let fluid therough, and you get a petal. then it slowly bleads out to the rrest of the line. and then no petal..
good luck.
stich626 is offline   Reply With Quote
Old 10-26-2010, 08:39 PM   #20
my67c20
First is everything plumbed correctly? From the photo it appears you have the front bowl plumbed to the rear output of the prop valve and the rear to the front output. It would also appear that the front bowl is the larger and should be plumbed to the front brakes.
http://67-72chevytrucks.com/vboard/s...d.php?t=184148
I looked thru your build thread (nice work) and it was hard to see everything around the prop valve and master cylinder. Some pictures would be nice.
Second do you have a long enough push rod in the master cylinder? Sometimes over looked.
Understand how those vacuum pumps work. Basically you create a vacumn in a bottle and when you open the bleeder it sucks stuff out, Only after doing this for hours will you effectively pull all the air out if the air is near the bleeder. A pressure bleeder is by far the best tool for forcing fluid thru the lines to create a steady stream.
Third adjust the rears until they really drag good. Remember spinning the wheel by hand and feeling a drag is different than a 3500lb vehicles idea of dragging.
How much of this bleeding has been done with the vehicle running and pulling a vacumn?
I suspect by your statement earlier on that the peddle fades leaves me to believe your master cylinder has some bad seals, or a plumbing problem
Did you buy the master chromed or did someone do it out for you?
Did you release the check valve after you bled and before you tested the system?
If you have no leaks you are 50% on your way.
my67c20 is offline   Reply With Quote
Old 10-27-2010, 09:47 PM   #21
Slick67
Sofa King Crazy!!
Slick67's Avatar
I did have it plumbed incorrectly, but fixed that.
Thanks! I' shoot some pics tomorrow of the new bracket and lines ran.
Yep, it's made for our trucks.
I am using a MytiVac and it does get fluid, but not enough. After redoing the prop valve today the issues may dissapear.
I adjusted them so that it is difficult to get the drum on and takes alot of grunting to move them when turning the 22 inch wheels.
One round, no exhaust yet so can't run it too long.
It is new from Tuff Stuff, rather expensive item so I don't think it's that.
Yes.
I did find one crack in a flare yesterday so that could be a major reason.
Old 10-29-2010, 09:01 PM   #22
Slick67
Sofa King Crazy!!
Slick67's Avatar
Problem Solved..........bad master cylinder. Thanks everyone for you're input, and hopefully this will help others!!!
Proof Positive!!!!!!!
