Old 10-28-2010, 01:53 AM   #1
crm318
Alright Alright Alright
crm318's Avatar
Symtoms and cures for vapor lock
I have noticed lately that when my truck gets hot from highway driving or even in town driving, the truck will have a low idle and sound like its going to die. It also sometimes wont start if it has been sitting and I have to use starter fluid. When this happens, gas is still squirting from the accelerator pump though. Tonight on the freeway, when ever I came to a stop, I had to keep my foot on the gas and brake to keep the truck alive. I also noticed that the clear fuel filter was empty and only little burps of fuel was going through it (I couldnt believe the truck was still running). The fuel pump is new. Could this be vapor lock? What are ways to cure this?
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 10-28-2010, 02:35 AM   #2
shiner2001
shiner2001's Avatar
Re: Symtoms and cures for vapor lock
If it is indeed vapor lock, a phenolic carb spacer can help some with that.
Derek
72 Chevy Cheyenne Super LWB 454 SS LS6
90 GMC Suburban V2500 350
64 Chevy El Camino 357
73 Jeep Wagoneer 360
78 Jeep Cherokee 360
79 Scout II 345
88 Jeep Wrangler 4.2L
91 Jeep Wrangler 4.3L
98 Lincoln Mark VIII 4.6L
01 GMC Yukon 5.3L
"If it's not broken, fix it 'till it is!"
shiner2001 is offline   Reply With Quote
Old 10-28-2010, 02:40 AM   #3
shiner2001
shiner2001's Avatar
Ha, crm318, just noticed your avatar...the donor car for my engine was a "Melba Toast," 70 Chevelle SS. I think the one in the movie might have been an LS5, but I still get a kick outta having that connection.
Derek
79 Scout II 345
01 GMC Yukon 5.3L
Old 10-28-2010, 05:39 AM   #4
cdowns
cdowns's Avatar
do you get a pressure buildup in your gastank? wwhen this happens try taking the gascap off , if you hear a whooshing sound that means you have a venting problem from not having the tank vented
many times with old vehicles there can be alot of crap in the tank. it is not unusual for the sock strainer on the pickup tube in the gastank to be clogged with gunk and crap
Old 10-28-2010, 07:16 AM   #5
cam.man67
cam.man67's Avatar
allright allright allright! I LOVE that movie!
And yes, Wooderson's Chevelle was an LS5.
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy"
1996 Gmc 1500 Z71, 350, 4l60e, 3.73s
1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s
1989 Toyota Pickup 22re, auto, 3.73
cam.man67 is offline   Reply With Quote
Old 10-28-2010, 12:21 PM   #6
jcis4me
jcis4me's Avatar
Aloha
"Man I love them red heads!"
Mine did the same thing I replaced and re routed the fuel line away from the headers and mounted the fuel pump on the out side of the frame rail, still was getting air in the fuel filter, put on new lines from the tank but still had the problem, so I changed the fuel pump and the problem went away, now I know you said you even put on a new pump , so I would check the fuel lines from the tank making sure they are all tight.
My buck 2.98's worth!
Aloha
Marty
PS btw our fuels now have alcohol in em and it evaporates faster than gas, I have heard here in Hawaii they want to add more alcohol to the gas! costs to much to import oil here I guess,
jcis4me is offline   Reply With Quote
Old 10-28-2010, 02:11 PM   #7
crm318
crm318's Avatar
I just had the had the tank out the other day to empty and clean it. The sender was clean and I removed the sock a while back. I will check the cap the next time it happens.
1972 Cheyenne
Old 10-28-2010, 03:13 PM   #8
BADPURPLE70CHEVY
406 Powered
BADPURPLE70CHEVY's Avatar
Had the same problem on a 68 once. Got a locking gas cap and it solved it. The locking cap seems to let the vapors escape better...just a thought
70 GMC
68 c10
2002 silverado
72 4x4
BADPURPLE70CHEVY is offline   Reply With Quote
Old 10-30-2010, 05:27 PM   #9
Little Red
Little Red's Avatar
I agree, A bad gas cap can definately cause vapor lock. Back in the 80's, I had a 77 Ford with the tank behind the seat and it would vapor lock on the freeway all the time. Used to reach out the window and pull out on the cap to release the pressure. Too lazy to buy a new cap back then.
I have a locking gas cap on my 69
Some days your the bug some days your the windshield!
69 C10 Stepside ~ Project
79 K10 Shortbed 4X4 ~ Sold
72 Chevelle SS Clone ~ Sold
Little Red is offline   Reply With Quote
Old 10-28-2010, 03:23 PM   #10
kevmic28
kevmic28's Avatar
What carb do you have? I have been dealing with this problem for a while now.
New tank, new lines, new fuel pump, new fuel filter and still there. The only thing I can figure is that my rochester carb float is sticking a occassionally or the choke. Its an intermittant problem. The only thing I can think it is my carb. Gonna replace it when I have the cash for an Edlebrock I think.
1970 GMC truck
1988 Harley 1200 Sportster
kevmic28 is offline   Reply With Quote
Old 10-29-2010, 09:36 PM   #11
vincentgkirkland
vincentgkirkland's Avatar
i pressurerd my tank with air and found my fuel line had a cracks in it and was sucking together and causing vapor loc replaced line and problem solved.
vincentgkirkland is offline   Reply With Quote
Old 10-30-2010, 02:57 PM   #12
crm318
crm318's Avatar
I have a quadrajet. Ill inspect the fuel lines.
1972 Cheyenne
Old 10-30-2010, 03:04 PM   #13
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Might sound crazy, but you can put a few wooden clothespins on the metal fuel line by the carb to act as a heat sink. Of course for a long time fix it would look pretty silly but if it cures your problem at least you know for sure it was vapor lock!
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 10-30-2010, 05:41 PM   #14
kevmic28
kevmic28's Avatar
Yep same carb as me. Im betting its the carb, at least for my issues. When mine bogs down and tries to die it I have a lot of smoke coming out only the drivers side exhaust pipe.
1970 GMC truck
Old 11-06-2010, 10:13 AM   #15
kevmic28
kevmic28's Avatar
So CRM318 did you fix your problem yet?
1970 GMC truck
Old 11-08-2010, 02:17 AM   #16
crm318
crm318's Avatar
Not yet Kevmic28. The other night I was stranded in a parking lot for 20 min while my truck cooled off. I notice that if I used starting fluid (which I didnt have on me), it will usually crank up.
1972 Cheyenne
Old 05-05-2017, 12:45 PM   #17
76 gmc k15
My dad has a 86 c10 with the 305 in it and it always vapor locked on us after shutting it off. I ended up cutting the metal line from the pump to the carb and replaced it with a rubber fuel line and moved it away from the engine as much as possible. Solved the problem. The factory fuel line was in-between the bock and water pump. It got so hot I couldn't even touch it with out getting burned. now I just have to fix the evaporation from the fuel bowls so we don't have to spend 15 mins to get gas to the carb every time. Thinking about putting in a 1 way valve.I'm only 18 btw.
1976 gmc k15-86 chevy c10-1994 chevy s10-03 chevy duramax 2500-05 Buick lacross
76 gmc k15 is offline   Reply With Quote
