Re: Symtoms and cures for vapor lock
Ha, crm318, just noticed your avatar...the donor car for my engine was a "Melba Toast," 70 Chevelle SS. I think the one in the movie might have been an LS5, but I still get a kick outta having that connection.
Derek 72 Chevy Cheyenne Super LWB 454 SS LS6 90 GMC Suburban V2500 350 ----------- 64 Chevy El Camino 357 73 Jeep Wagoneer 360 78 Jeep Cherokee 360 79 Scout II 345 88 Jeep Wrangler 4.2L 91 Jeep Wrangler 4.3L 98 Lincoln Mark VIII 4.6L 01 GMC Yukon 5.3L "If it's not broken, fix it 'till it is!" |
do you get a pressure buildup in your gastank? wwhen this happens try taking the gascap off , if you hear a whooshing sound that means you have a venting problem from not having the tank vented
many times with old vehicles there can be alot of crap in the tank. it is not unusual for the sock strainer on the pickup tube in the gastank to be clogged with gunk and crap
#3 | |
![]() And yes, Wooderson's Chevelle was an LS5.
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy" 1996 Gmc 1500 Z71, 350, 4l60e, 3.73s 1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s 1989 Toyota Pickup 22re, auto, 3.73 |
![]() Join Date: Aug 2010
Aloha
"Man I love them red heads!" ![]() Mine did the same thing I replaced and re routed the fuel line away from the headers and mounted the fuel pump on the out side of the frame rail, still was getting air in the fuel filter, put on new lines from the tank but still had the problem, so I changed the fuel pump and the problem went away, now I know you said you even put on a new pump , so I would check the fuel lines from the tank making sure they are all tight. My buck 2.98's worth! Aloha Marty PS btw our fuels now have alcohol in em and it evaporates faster than gas, I have heard here in Hawaii they want to add more alcohol to the gas! costs to much to import oil here I guess, Last edited by jcis4me; 10-28-2010 at 12:24 PM. |
