Old 11-05-2010, 12:55 PM   #1
veinbar
veinbar's Avatar
Transmission won't release drive shaft.
I've dropped the rear and mid sections of my drive shaft, and now I'd like to pull it out of my transmission. I've performed this on a few vehicles, but I've never come across one that didn't slide out. The drive shaft is stuck in the transmission. It's a th400 in a '79 silverado. Ive pulled,twisted and turned, and delicately tried prying it free. I'm open to tips and suggestions. Thank you in advance.
veinbar is offline   Reply With Quote
Old 11-05-2010, 03:30 PM   #2
swb85
On a budget like Fred Sanford
swb85's Avatar
Re: Transmission won't release drive shaft.
If it's a slip yoke connection, it's either corroded or the splines of the slip yoke and/or tail shaft are twisted. I've twisted a yoke bad enough on my nitrous car to need a 3lb sledge to get the drive shaft outta the trans.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 11-05-2010, 06:45 PM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
dont be so gentle whack it a couple of times with a hammer if a large prybar doesnt work
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 11-05-2010, 07:48 PM   #4
dammitmitchell
the pollock
dammitmitchell's Avatar
tie a strong rope get out from under the truck and pull hard. over and over again..
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 11-05-2010, 10:00 PM   #5
80SPORT
80SPORT's Avatar
The TH400 used in the trucks has a bolt in the center of the yoke ;there should be 4 capscrews retaining the ujoint clamps...the same as the companion flange at the rear axle.
The slip yoke part is on your rear driveshaft;be sure to mark the position of the shafts if you split them as they are phased and balanced together.
80SPORT is offline   Reply With Quote
Old 11-06-2010, 02:00 AM   #6
KQQL IT
At the body shop.
KQQL IT's Avatar
If its a two piece drive shaft its bolted.
one piece is a slip yoke
