12-08-2010, 01:26 AM | #1 |
Exhaust routing pics
i need some pics of how you guys ran your pipes over/under the transmission crossmember. i have long tube headers on my 2wd and they look to come out at a tricky angle towards the crossmember. also any pics of x pipes would be sweet too
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] |
12-08-2010, 01:31 AM | #2 |
Re: Exhaust routing pics
im in the process of fabing a new one when i get it done ill post some pics. i had the same problem
Lindsey Rae 85' chevy long box, built by a girl! My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=429956 |
12-08-2010, 01:41 AM | #3 |
thanks
12-08-2010, 01:44 AM | #4 |
no probs. might be a couple days though bear with me.
12-08-2010, 01:50 AM | #5 |
oh i'm in no hurry lol just getting ideas
12-08-2010, 05:52 AM | #6 |
I have a 3 in x pipe system from pypes and long tube headers all I did was take a U shaped pipe cut it in the middle and made a _/--- shaped tube kinda like an odd S and it works great otherwise I'm going to drop the trans crossmember and either make it hollow or notch it to match the other side I can take pics if you like
Posted via Mobile Device |
12-08-2010, 04:43 PM | #7 | |
12-08-2010, 06:12 AM | #8 |
BAD BOW-Silverado XST
12-08-2010, 08:16 AM | #9 |
78K & 79C Jimmys
was told it did have headers before
but this was on it when i bought it about 2months ago
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
12-09-2010, 11:59 PM | #10 |
God is good!
Question for you--how in the heck do you have access to your starter? I'd like a similar set-up but just can't see how the starter fits through there with the pipe in the way.
Mando "It takes a smart man to know when he's stupid." -- Barney Rubble My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367 |
12-10-2010, 02:13 AM | #11 | |
78K & 79C Jimmys
12-08-2010, 05:06 PM | #12 |
On my 82 with 3" duals, one pipe went over the cross member and the other went pretty much straight under it. It wasn't real bad... but again I wasn't real concerned with looks though it did come off a "show" truck... sorry no pics.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
12-08-2010, 09:50 PM | #13 |
that's what i'm thinking i'll have to do, one pipe over and the other under the crossmember. just as long as the pipes aren't touching anything lol that's what i'm fighting with right now...
12-08-2010, 10:14 PM | #14 |
I am building a new crossmember out of 2x3 tubing so I can run both pipes above it. The over/under thing drives me crazy.
12-08-2010, 10:13 PM | #15 |
OutOfMyMind & I'llNeverKnowWhy
Mine with hedder long tubes.
-Justin-Out of my mind and I'll never know why 1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed 1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6 1992 Pontiac Firebird T-Top 5.0L TBI 700R4 My cardomain page I don't like to save, it's more fun to spend!! |
12-08-2010, 10:31 PM | #16 |
Salty Sailor
Heres what i did with full length headers
86 c-10 Custom Deluxe Savannah, Georgia |
12-09-2010, 12:34 AM | #17 |
I will post close up pics tomorrow of my x pipe system with the pipe bent up over the crossmember
12-09-2010, 12:41 AM | #18 |
thanks guys, i love seeing pics
Justin, is that an aftermarket crossmember? mine looks like bucannon's
............._____l __\__ ..............l_(O)_ l___(O)] Last edited by GMC Guy; 12-09-2010 at 12:43 AM. |
12-09-2010, 11:39 PM | #19 |
Mine is the stock early style.
-Justin-Out of my mind and I'll never know why 1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed 1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6 1992 Pontiac Firebird T-Top 5.0L TBI 700R4 My cardomain page I don't like to save, it's more fun to spend!! Last edited by Justins76; 12-09-2010 at 11:40 PM. |
12-10-2010, 02:07 AM | #20 |
Insert Witty Text Here
Maybe try an older double hump crossmember? That's what i have for mine. It will go on when I re-do the exhaust. It was $15 from a junkyard. I got it off an old Big10 or Heavy Half.
Slonaker |
12-10-2010, 03:05 AM | #21 |
that's what i'm thinking...willl it bolt right up? and will it fit with a 700r4 which i plan to swap in the near future
12-10-2010, 09:56 AM | #22 |
that's my same question....if so...I'll be going to find one...
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
12-10-2010, 09:50 AM | #23 |
Even with long tube headers the starter just barely slid out. I have heard of some people having to unbolt the headers from the engine to get enough room. I did not have a problem though. Just had to move it around a bit until it was in the right position.
12-10-2010, 12:15 PM | #24 |
It will fit on the 700r4 but you have to drill holes in the frame because the crossmember sits farther back with a 700r4 compared to the stock th350.
12-10-2010, 12:49 PM | #25 |
78K & 79C Jimmys
thought i'd have a better pic but this is it
