Wiring a '63 2-speed wiper switch
I found a 2-speed wiper switch with a push button for windshield solvent spray. The switch has three wires: Black, light blue & dark blue. I looked in my '63 shop manual, but the only wiring diagrams are for single speed switches. This is a new installation, so there are no old wires to follow. Can anyone tell me which wire goes where?
Thanks, -Bob |
Resistance is Futile
Re: Wiring a '63 2-speed wiper switch
My truck has this option and I'll try to get the info this weekend as I'm cleaning up some wiring stuff.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
Thanks, protrash64. I'll watch for your reply.
Thanks and Merry Christmas! -Bob |
Senior Enthusiast
Cool link, Mark. My switch doesnt work properly. Wipers only turn on when the fluid button is pushed; sounds like it may be a grounding issue from the description.
#6 | |
That's exactly what I was looking for - thanks a million for helping me out! -Bob |
1 thing at a time is progress.
Did a search and this thread came up.
I've tried using the diagram in the above thread. Persh link Does everything have to be hooked up such as the pump? I'm not gonna run a pump. I'm not getting anything. I bench checked the motor and it checked good I think. I got two speeds and park. I don't know how I did it cause I didn't have a good switch. I just unhooked wires until I got 2 speeds and park. Now the motor is in and I have a good (new) switch. Here's my motor
Alan
Philippians 2:14-16 Last edited by Alan's Classic; 03-30-2012 at 08:22 PM. |
bump for previous question.
I don't know if the wiper motor is a factory replacement, I think not. help appreciated.
Alan
Philippians 2:14-16 |
Hi Alan,
No, you don't need the washer pump hooked up to make the motor work. The black w/yellow wire is a +12V feed that's live whenever the ignition switch is on. For low speed, the switch grounds both the black and black w/blue wires. For high speed, the switch only grounds the black w/blue wire. Check to make sure your switch is making good electrical contact where it mounts to the dash. If the dash has been repainted it might be keeping the switch from making good contact. |
#10 | |
Alan
Your the man!! I grounded the switch and what do you know it worked. Thanks again.
Alan
You're welcome!
Glad to hear it was a simple fix ![]() |
im doing the same conversion. my donar motor and pump came from a 63 c10, but my wire colors are different.-
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 03-25-2013 at 10:52 AM. |
Heres a few pics of my two speed wiper w/washer. Shows part # 5045342 Type E 12V delco appliances date code Jan 63
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
