Old 12-22-2010, 02:23 PM   #1
justagoodolboy
Under Construction
justagoodolboy's Avatar
Drop Spring Length ?
My buddy has a stock height 72 c10 and he found a guy that has a set of drop springs for sale. Only problem is, he does'nt know what drop the springs give. He said the front springs are 10 and 3/4 inches long and the rears are 8 and 1/4 inches. Can someone please tell me how much drop these springs give?
72 chevy 4x4-my project
67-72chevytrucks.com/vboard/showthread.php?t=368210
94 Nissan 4x4-Daily Driver and off road beater
03 Saab 9-3 -tripper
90 Polaris Trail Boss- 2 Stroker
justagoodolboy is offline   Reply With Quote
Old 12-22-2010, 03:35 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Drop Spring Length ?
Are the springs made for the 67-87 trucks?
88-98?
99-06?
It's going to be hard to tell,... just using the length.
Keith
Convert to disc brakes.
Old 12-22-2010, 04:32 PM   #3
justagoodolboy
Under Construction
I believe the springs are for 67-87. Seems like I remember reading that stock height rear springs are 13 inches (uninstalled) If so, that would put the rear at about a 5 inch drop if I'm right on that.
Does anyone have a set of drop springs you could measure for me? And tell me X length spring for X amount of drop and that way I can compare lengths and figure out about how much drop these give?
Old 12-22-2010, 04:52 PM   #4
Shane
Shane's Avatar
you can't really measure the height of a coil spring and it correlate directly with the amount of drop.
the coil "rate" has a lot to do with the amount of drop a spring will give, in other words the amount the spring "squishes" once the weight of the truck is applied varies from one maker to others depending on the diameter/size of the round bar used to make the spring ... and even the annealled state of the material can have an affect on the amount of drop.
Shane is offline   Reply With Quote
Old 12-22-2010, 05:05 PM   #5
lolife99
lolife99's Avatar
Shane is correct.
I had a set of 2" drop springs that were the same height as a different brand of 3" drop springs. (un-installed height)
Keith
Old 12-22-2010, 06:28 PM   #6
justagoodolboy
Under Construction
Thanks for your replies. I guess I thought drop springs were drop springs and never gave it a thought that they might vary.
