Old 01-15-2011, 01:58 PM   #1
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Junk yard find.
Today went to the Junk yard (in the snow lol)
Found a Guage cluster truck with the dash harness unmolested! yay! but..... after i pulled it out i got looking at the truck it was manufactured on 07/86.... making it an 87 EFI if i'm correct? will he harness work in y 84 350 that i want to swap guage cluster into? every thing looks to be the same... for the $5 bucks i payed for it i'm not going to complain. thanks
Also the interior was A dark Chocolate brown (is this factory?) Looked really nice.
If it aint square, I don't care.
84 C35 CC Dually Project log...
http://67-72chevytrucks.com/vboard/s...d.php?t=414892
1tonchevy is offline   Reply With Quote
Old 01-15-2011, 02:54 PM   #2
Doug_J
Doug_J's Avatar
Re: Junk yard find.
It is possible that manufactured date is 86 but look at the VIN an see if it says 87.
Doug_J is offline   Reply With Quote
Old 01-15-2011, 02:54 PM   #3
sandorjoben
sandorjoben's Avatar
Re: Junk yard find.
The only difference I can think of off the top of my head is that if your old cluster had a choke light on the speedo, it may have check engine text now instead because of the fuel injection on the 87 truck you pulled it from, but should function the same to my knowledge. My 87 is using a cluster from an earlier year vehicle and reads "Choke" instead of check engine and works fine.
Dave
87 GMC V15 in profile photo sold 2013
99 Chev Silverado 2500 5.3 reg cab long bed
sandorjoben is offline   Reply With Quote
Old 01-15-2011, 03:14 PM   #4
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Re: Junk yard find.
Dave
Ok because my truck is originally a Warning light set up not gauges but i'm swapping in gauge cluster lol that and y harness has been hacked to sh*t :S
Old 01-15-2011, 04:08 PM   #5
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: Junk yard find.
7/86 would still be an 86. Usually new year models were September at earliest, usually October though. Every once in a while they get weird on it, like the "88" model trucks actually came out between 2/87 and 4/87 if I remember, Keith would probably know more exacts if he'd chime in.
And... speak of the devil, spooky huh? LoL
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 01-15-2011, 04:10 PM   #6
Keith Seymore
Keith Seymore's Avatar
Re: Junk yard find.
Scary, huh....
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-15-2011, 04:06 PM   #7
Keith Seymore
Re: Junk yard find.
Could be a very late '86 model carbureted truck.
I don't believe we started the '87 model year until August/September. In fact, some powertrain combinations were later than that because the EPA was backlogged with the emissions certification testing.
K
1979-1986
1986 - 2019
Old 01-15-2011, 04:10 PM   #8
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Re: Junk yard find.
K
so it will work?
Old 01-15-2011, 07:19 PM   #9
sandorjoben
Re: Junk yard find.
When you say your original cluster only had warning lights did you mean like the one in the image on the bottom right? Then picked up a cluster with the actual volt/temp/oil pressure gauges from the wrecker?, Check to see if the printed circuit papers on the back are the same, your gauges may only work if the proper senders are installed. If that's what you're asking.
Dave
Old 01-15-2011, 07:27 PM   #10
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Re: Junk yard find.
Dave
yeah... but i have read some where you can re pin your warning light harness to work... but mines so hacked it's easier to just swap it out.i am just going to swap and see i guess :S
