New Carb
Just swapped the quadrajet for an Edelbrock 600 performer. Runs great after hitting the throttle but sure idles rough. I hooks a vacuum gauge to it and set the idle mixture at high vacuum but still sounds like it has a race cam in it!!
Re: New Carb
Vacuum leak!!! What kind of adaptor did you use?
Re: New Carb
Used an edelbrock 4 hole quad to square bore adapter.
Re: New Carb
Where's the air-fuel mixture screw?
Grandpa in the rustmobile...
Re: New Carb
it only has 2 screws 1 is air 1 is fuel I believe
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Re: New Carb
Could it be the float level? I took the vacuum plug off to hook the gauge up and it idled smoother.
Desert Rat
Re: New Carb
Re: New Carb
Can't find any vacuum leaks. maybe it ain't supposed to idle smooth!
BAD BOW-Silverado XST
Re: New Carb
If you have a vacuum leak, the gauge would tell you. Is the needle steady or moving? What are the RPMs at idle? Which tranny are you running? A 700R4 should have the angle correction bracket installed.
http://www.centuryperformance.com/tu...e-spg-148.html |
Re: New Carb
it has the 700r4 bracket. vacuum gauge is a little jumpy. sprayed ether around fittings and no reaction.
Did readjust float level and helped a little. |
Re: New Carb
GO TO Edelbrock.com. They have a bunch of tuning videos for their carbs. Very informative.
http://www.edelbrock.com/automotive_...ech_vids.shtml Last edited by rayfinseats; 03-13-2011 at 10:41 PM. |
Re: New Carb
Anybody ever drill holes in the primary butterfies?
#15 |
Re: New Carb
How did you install the egr? mine was sucking air through the manifold and it ran super high and rough. If you need a block off for the egr take the spacer on the egr fill with jb weld bake at 400 for 30m and place gasket sealer on it
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ] ![]() 1999 k3500 crew cab dually 6.5tdi/4l80e |
#16 |
Re: New Carb
Will do. Thanx!!
#17 |
Re: New Carb
Just blocked off the EGR valve and it idle as smooth as the top of my head!! Thanks for all the advice!!
#18 |
Re: New Carb
Yea, I run mine without the EGR valve!!
#19 |
Re: New Carb
Whats the EGR tube lol
#20 |
Re: New Carb
Glad it worked for you. The egr is just an obstruction anyway.
