Old 03-14-2011, 02:00 PM   #1
woodwright
Enjoying left field
woodwright's Avatar
rear u-bolt flip
Hey guys, quick question. I'm building a 70 K10, and I would like to flip the u-bolts in the rear so they go up like the front. Could I use top spring plates off the front? I have an extra set.
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 03-15-2011, 02:10 AM   #2
woodwright
Enjoying left field
woodwright's Avatar
Re: rear u-bolt flip
Anybody?.........Bueller?........Bueller?.......
Clint
Old 03-15-2011, 03:45 AM   #3
1malo68
1malo68's Avatar
I don't know what kind of rear / front end you have, but I would have to say No unless the holes are slotted. The passenger side uses 2 different sized ubolts. The easiest thing to do is get out the trusty tape measure.
1968 K10/30
Frame Off Project "Overkill"
My 5 year, $30,000.00 toy
1malo68 is offline   Reply With Quote
Old 03-15-2011, 06:58 AM   #4
eric67m
eric67m's Avatar
I thought the earlier 67-72 had nuts up. Later 73+ had the nuts facing down in the rear. Check out ruffstuffspecialities.com or diy4x4.com. It seems like i saw a kit to put the nuts uppward one of those places.
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job"
eric67m is offline   Reply With Quote
Old 03-15-2011, 07:54 AM   #5
duallyjams
duallyjams's Avatar
The axle tube are different size from front to back so no you will need the correct spring plate for the rear.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 03-15-2011, 10:47 AM   #6
woodwright
Enjoying left field
woodwright's Avatar
Ok, thanks for the answers.
Clint
Old 03-15-2011, 11:54 AM   #7
eric67m
eric67m's Avatar
What axle is in your truck? Do you have any pictures? I am only really familiar with 67-68 which point up. What year did they change from up to down, at the factory?
Here is the one that I was thinking of, by off road design.
http://offroaddesign.com/catalog/uboltreversal.htm
Here are several from ruff stuff specialties (I used the 14 bolt simple swap on my truck). You wouldnt neccessarly need to replace the spring perch.
http://www.ruffstuffspecialties.com/...123bc9e924ecbe
Old 03-15-2011, 02:48 PM   #8
woodwright
Enjoying left field
woodwright's Avatar
My parts truck is a 70 1/2T. It has a 12 bolt rear and a dana 44 in the front. The. Front is nuts up, and the back is nuts down.
Clint
