Eagle Alloy 225's, 20". Do I need an offset?
Hey all, so on monday I'm going to bite the bullet and finally order these rims. Now I've already asked the backspacing question, and was told to go with a 5" on the front rims (20x8.5) and a 5.5" on the rear (20x10) now that part was easy but I'm not sure if I need an offset either? everything is stock on the truck (79 SWB Scottsdale) but in the future I will upgrade to disc brakes on the rear. Also I plan on doing a 3/5 drop on the truck as well. Thanks for the help, this just happens to be one of those items on the truck which makes me super nervous as i don't want to order them and they not fit when they get here.
As for tires I've been recommended to go with the 255/40-20's on the front and the 295/40-20 on the rear. Think that'll work with everything??? Thanks! |
#2 | |
Re: Eagle Alloy 225's, 20". Do I need an offset?
An 8" wheel w/4.5" back-spacing is the same thing as an 8" wheel w/zero offset. I used 8" front wheels w/5-5.25" back-spacing. The 5" keeps you off the a-arm lip more. The 10" rear wheel would be pretty close to the inner tub wall @ 5.5" back-spacing. It will fit but you'd have more clearance & still fit w/5.0 back-spacing.
I went with 20x10s on all 4s and with the 5.5 BS
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 |
How's ur turn radius? Does it rub much?
Posted via Mobile Device |
Dude that is one nice burb you have if you havent heard it before.
Flowershop Hip Hop & Street Rods Dropmember 83 Custom Deluxe Almond on Almond 85 Silverado White on Red/Now Chevy LeMans Blue Rendering in Truckin magazine vol 36 no. 11,2010 |
its bagged, i can turn it almost full turn aired out, i have some 1in shorter a-arms i am going to put on so i can turn full all the way down.
wow that is one nice burb, and pretty much re-affirms my choice of rims hehe, So realistically I should stick with the 5" back spacing on front and rear then for ease of fit? or stick with the 5.5 in the rear as justpball doesn't seem to rub in the rear.
thanks! |
#8 | ||
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-20-2011 at 09:30 AM. |
Thanks for the help, going to order the wheels tomorrow with 5" backspacing on all of them. Seems like that will be the best fit with some clearance.
Thanks again |
I am even running spacers just on the rear to push them out some
![]() Join Date: Jan 2010
How in the world can you run 10" all around? I was going to do 5" front and 6" in rear,can you do 10" on the front?
you will need 5.5 in the front
I had 20x8.5" Coys w/5.25"BS on my 74 & they cleared the front fender lips w/o ever contacting. 5"BS would have worked on mine as well & would have required less trimming on the a-arm lip thus why I suggested it.
I haven't looked up the Eagle 225's so I'm not sure what BS options are even possible but anything between 5-5.75" would work. Anything less than 5" & you really have to watch the outer fender lip on >4" front drops. Anything more than 5.75" will start bumping stuff closer to the inside wall of the wheel well. Pics of my 74 w/the Coys (20x8.5" w/5.25"BS) & one of N2billets 'Lucy' w/some Vintecs (20x8.5" w/5.75"BS). Both trucks had 255/40-20 Toyo Proxes up front.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-20-2011 at 05:40 PM. |
2259-2012 20x10 Polished 5 on 4.5 +2 mm 5.500 3260-09 2100 lbs. lbs.
2259-2015 20x10 Polished 5 on 115mm +8 mm 5.75 3260-09 2100 lbs. lbs. 2259-2028 20x10 Polished 5 on 4.5 +14 mm 6.000 3260-09 2100 lbs. lbs. 2259-2029 20x10 Polished 5 on 4.5 +40 mm 7.00 3260-09 2100 lbs. lbs. 2259-2050 20x10 Polished 5 on 5 +2 mm 5.500 3260-09 2100 lbs. lbs. 2259-2059 20x10 Polished 5 on 135mm +2 mm 5.500 3260-09 2100 lbs. lbs. 2259-2080 20x10 Polished 5 on 4.75 +2 mm 5.500 3260-09 2100 lbs. lbs. 2259-2081 20x10 Polished 5 on 4.75 +14 mm 6.000 3260-09 2100 lbs. lbs. 2259-2085 20x10 Polished 5 on 5 +14 mm 6.000 3260-09 2100 lbs. lbs. 2259-2812 20x8.5 Polished 5 on 4.5 -5 mm 4.5 3260-09 2100 lbs. lbs. 2259-2815 20x8.5 Polished 5 on 115mm +8 mm 5.000 3260-09 2100 lbs. lbs. 2259-2821 20x8.5 Polished 5 on 120mm +33 mm 6.00 3260-09 2100 lbs. lbs. 2259-2828 20x8.5 Polished 5 on 4.5 +8 mm 5.000 3260-09 2100 lbs. lbs. 2259-2829 20x8.5 Polished 5 on 4.5 +21 mm 5.500 3260-09 2100 lbs. lbs. 2259-2850 20x8.5 Polished 5 on 5 -5 mm 4.5 3260-09 2100 lbs. lbs. 2259-2878 20x8.5 Polished 5 on 4.75 -5 mm 4.5 3260-09 2100 lbs. lbs. 2259-2885 20x8.5 Polished 5 on 5 +8 mm 5.000 3260-09 2100 lbs. lbs. Ok thats what's available from aewheel, so I guess that settles it hehe, 5.5 rear, and 5 in the front |
#15 |
good info here, a common question
1979 c30 3+3 dually 1946 GMC |
