Old 03-19-2011, 12:19 AM   #1
twalker
twalker's Avatar
Unhappy Truck has the shakes
First post but long time reader. I have a 1984 C10, static drop front and rear, recently had new tires and front end alignment. While driving between 55-65 mph the truck shakes at certain spots. I had the shop check the tire balance and all was good. What can be causing this?
twalker is offline   Reply With Quote
Old 03-19-2011, 01:04 AM   #2
2badgn
Re: Truck has the shakes
Flat spots on tires? Bent rim(s)? Suspension problems? Brake problems?
2badgn is offline   Reply With Quote
Old 03-19-2011, 01:10 AM   #3
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Has it seen a ford lately?
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 03-19-2011, 12:38 PM   #4
Toxic Redline
Toxic Redline's Avatar
did they "Road Force" balance them? sometimes the rubber can have high and low spots that doesnt effect until a certain MPH, also could be a bent driveline
84 K20 Long Box W.I.P
78 Burb - parts now [Rolled]
68 c20 dump bed
WHEN IN DOUBT--- FLOOR IT
Toxic Redline is offline   Reply With Quote
Old 03-19-2011, 09:25 PM   #5
sjreno
34psi on a 78mm Turbo??? Thats pretty serious!! You need spray to get that thing spinning??
I too have a 2.7, but its not in a ford, and my 2 turbos are MUCH SMALLER. Unsuspecting V8's, and some V10's have no clue
sjreno is offline   Reply With Quote
Old 03-20-2011, 01:23 AM   #6
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
I don't see boost until 3500 when just driving. That isn't full boost either, it's just starting to come in. The car has a 50 shot on it to help the spool. I haven't really had any issues, it'll leave off of the trans brake or via brake boosting from a roll.
04 Pontiac GTO
04 Ford Mustang GT
73 K5 Cheyenne
88 K20 Suburban
Old 03-19-2011, 09:18 PM   #7
sjreno
call me crazy, hows the U joints in the drive shaft? Had this problem with my 2000 silverado, and it racked my brain but good trying to trouble shoot. Changed out the u joints with new ones, problem solved.
Old 03-20-2011, 07:45 AM   #8
Lost 40
Lost 40's Avatar
Smile Re: Truck has the shakes
X2. I just had my U-joint fixed yesterday. Anything over 50 mph, and I had this horrible shaking. Would even go away for a few seconds at a time. I just bought the truck a couple weeks ago and the truck has a shift kit in it. So I had a hunch the U-joint might be bad. Sure enough, it was shot. Had it fixed, and then still had a small vibration. I noticed my rear tires were cupped, and I had one front tire that had seperated a little. I replaced all the rubber same day, and now she rides like a dream from the drop off the hammer, to chirping the tires in second, through the top end of the speedo. I was a very happy guy. Long story short, get your U-joint looked at.
1986 Chevy C10
2" Drop
350 SB
350 Turbo Trans
"Keep it rubber side down, in between the ditches"
Lost 40 is offline   Reply With Quote
Old 03-20-2011, 08:57 AM   #9
LONGHAIR
Assuming that the more obvious things have been eliminated... balance, bent wheels, etc., look at the driveshaft itself. I have seen them bent by improper positioning of the lift.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 03-20-2011, 11:33 PM   #10
twalker
twalker's Avatar
Thanks for the replies fellas. I'll check the u-joints and driveshaft since it has a shift kit installed. I got the truck last year and trying to fix the previous owners mess.
