First post but long time reader. I have a 1984 C10, static drop front and rear, recently had new tires and front end alignment. While driving between 55-65 mph the truck shakes at certain spots. I had the shop check the tire balance and all was good. What can be causing this?
Re: Truck has the shakes
Flat spots on tires? Bent rim(s)? Suspension problems? Brake problems?
NOT REALLY BANNED!
![]() Join Date: Jul 2004
Has it seen a ford lately?
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily. 04 Pontiac GTO 04 Ford Mustang GT 68 C20 LWB stripper truck 73 K5 Cheyenne 76 C20 Sierra Crew SRW 88 K20 Suburban I'm not hammering on metal just to hammer, i'm creating a piece of art. |
did they "Road Force" balance them? sometimes the rubber can have high and low spots that doesnt effect until a certain MPH, also could be a bent driveline
84 K20 Long Box W.I.P ![]() 78 Burb - parts now [Rolled] ![]() 68 c20 dump bed ![]() WHEN IN DOUBT--- FLOOR IT
call me crazy, hows the U joints in the drive shaft? Had this problem with my 2000 silverado, and it racked my brain but good trying to trouble shoot. Changed out the u joints with new ones, problem solved.
NOT REALLY BANNED!
I don't see boost until 3500 when just driving. That isn't full boost either, it's just starting to come in. The car has a 50 shot on it to help the spool. I haven't really had any issues, it'll leave off of the trans brake or via brake boosting from a roll.
#8 | |
1986 Chevy C10 2" Drop 350 SB 350 Turbo Trans "Keep it rubber side down, in between the ditches" |
#9 | |
Assuming that the more obvious things have been eliminated... balance, bent wheels, etc., look at the driveshaft itself. I have seen them bent by improper positioning of the lift.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right.
Thanks for the replies fellas. I'll check the u-joints and driveshaft since it has a shift kit installed. I got the truck last year and trying to fix the previous owners mess.
| Bookmarks |
