04-29-2011, 08:35 PM | #1 |
Throttle Pedal measurement needed
Can anyone measure the distance from the top edge of their gas pedal to the floor/carpet? My truck is a 69, without the cable.
Thanks CST350 |
04-29-2011, 09:52 PM | #2 |
Cops, ha, catch me if you can!
Re: Throttle Pedal measurement needed
I don't have an answer for you, but maybe some more info from you to help someone answer it. Do you want this measurement to see how long of a cable you need? Are you trying to figure out the position of the pedal when you install your cable?
72 C-10 Stepper 350/TH350 3.73 in the back Edelbrock intake and Carb Hooker Comp Headers 275/60R15 on Rallies |
04-30-2011, 12:21 AM | #3 |
I have the other style, the solid rod. The difference from stock is that I'm running a Demon carb, so I dont know how long to adjust the rod so the pedal is in the stock position.
04-30-2011, 12:39 AM | #4 |
Who's got steelies?
If you use the factory adjustment method, I bet you can get close without measuring. Basically you just push the pedal till the lever hit the bump stop & hold it & with the carb at WOT adjust the thing on the rod till it goes in the hole on the throttle lever on the carb. Should put you in the ballpark.
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
