Steering way to loose
My steering has way to much play in it, and all the steering parts are brand new and all the nuts and bolts are tight. What do I need to do to tighten it up? Also the truck is 4 wheel drive will be waiting to hear how to fix this
It's not what you buy, It's what you build |
Robert Olson Transport
![]() Join Date: Oct 2002
Re: Steering way to loose
define loose.. compared to the newer trucks the steering on these trucks is sloppy and loose.. its just normal for most of the trucks of this genre tho
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
#3 | |
The wheel has about 1/4 play in it and thats not right cuz i also have a 80 c20 it does not have that much in it of play in it, i know there is play in these trucks but not this much
It's not what you buy, It's what you build Last edited by Rbcustoms; 05-23-2011 at 09:51 PM. |
The One And Only !!!
There's a stud sticking up on top of the steering box cover plate with a lock nut on it, Loosen the nut and turn the stud with a allen wrench inward 1/4 turn at a time until most of the slop is gone. Keep your hands off/away from the steering wheel when you start the engine after adjusting, If you go too far in with the adjuster the wheel could snatch around as the engine fires and take a finger/thumb out.
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
thanks ill go try that right now and see what it does
Be careful adjusting it that way and test by turning lock to lock after each adjustment. You may find the slop is gone, but it binds when turning.
Here is a thread where guys replaced the rag joint with Jeep XJ steering shaft. Never did it but they said they had great results...
http://67-72chevytrucks.com/vboard/showthread.php?t=382088
86 C20 2wd with 454 and Turbo 400 |
