Lowest drop without bags...HELP PLEASE!!
hello again, I went to the POL parts company and love there stuff. But I was set on the LMC slam kit with 4 1/2 front to 5 rear for my '68 C-10. Now, Im confused because POl.com doesn't have such a kit. Just 2 1/2 drop spindle and separate drop springs 1'' 2'' 3''. PLEASE HELP!! I dont plan to use bags at all. My father has MS and he can hardly get into it at stock height. I want him to be able to just slide right in and have it look SUPER LOW. What should I use to have the equivalent of LMC'S slam kit. wehwwww!! Any help is soo appreciated!
Re: Lowest drop without bags...HELP PLEASE!!
MY STEP SIDE HAS A 6/7.5 DROP
3INCH SPINDLES AND 3INCH SPRINGS UP FRONT IT THE REAR I GOT 6 IN SPRINGS WITH A 1.5 IN LOWERINGBLOCK BUT YOULL HAVE TO INSTALL A bolt in c notch
70 SWB STEPSIDE 70 BLAZER 09 challenger |
67-72 parts collector,…
![]() Join Date: Nov 2002
Use POL's 2.5" drop spindles and 2" drop springs up front.
Then add a 5" rear spring. Stay away from LMC. They make great catelogs,... but there are better suspension companies to buy 67-72 parts from. Early Classsic Enterprises would be another good choice. (they sell a 6" rear spring) Dont forget drop shocks, rear shock relocators and an adjustable track bar. This is member 72BlckButy's 69 swb with a 4.5/6 drop from ECE.
Laid Back
![]() Join Date: Apr 2010
Mines 5.5 front and 8 rear works great
72 chevy swb Direct dealers for.. Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body.. Kyle http://67-72chevytrucks.com/vboard/s...d.php?t=574629 |
Get the 4/6 kit from ECE and you won't have any regrets. It will still be plenty low enough and you won't need a c-notch. If you want it lower, you will need to c-notch the rear.
![]() Join Date: Jun 2011
4/6 ece and c notch.
///Relaxed Atmosphere
2-1/2"DROP SPINDLES & 2" SPRING FRONT, 6" INCH DROP SPRING REAR,NO C-NOTCH. Drop Kit from ECE you will not be dissapointed.
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R) 87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R) hector _________________________________ 1971 Chevrolet Cheyenne Super 1987 Chevrolet Silverado 2006 Ford Mustang GT 2012 Toyota 4-Runner 2014 Dodge Ram 1500 Sport Crew Cab |
#9 | |
454 MAKES IT ROAR
![]() The only prob is, should you ever intend on hauling anything your truck will be useless, bags will give you the best of both.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
#10 | |
If you plan on hauling heavy loads,... rear bags will definitely help. Useless is pretty harsh.
#11 | |
![]() ![]() ![]() ![]() It was built to go fast and show off! ![]() I have an '07 Silverado for all that "hauling stuff". |
Hey thanks again guys, this works out great. I planned on putting in a c-notch as well but forgot to mention it. what setup should I use then with the notch kit
6" rear drop springs and add drop blocks to get desired drop.
454 MAKES IT ROAR
^^^Ahhh!! the engine of my dreams^^^
Beautiful Truck Fitz.
#15 |
Thanks! 3000 hours and waaay too much money, but it sure is fun!
Hear it? http://s851.photobucket.com/albums/a...urrent=572.mp4 |
#16 |
Rather than bags, how about air shocks? Just enough to bring the bag end up when you have a load.
#17 |
needs more $$$
I have air shocks in my S10's rear for this reason, but I hear it's not the smartest thing since the shock mounts weren't designed to take that much load. I have only used them twice, but in almost 2 years the mounts are still in perfect shape. I don't know how different it would be for the heavier C10.
1970 2wd Blazer |
#18 | |
![]() Join Date: Sep 2013
71 LWB Large Bore 6-71 Blown 383 Stroker 4.11 Motive/EOM Eaton Posi Ported/Polished Carrier 15x8/15x16.5 MT Radials B&M Pro Shifter Truck Name- Spike |
#19 |
Here's my gal. Going thru a radical change this week....vroom vroom...
