Anyone have power steering pump pic's
Looking for some pictures on power steering mounting hardware, i bought a bracket at longbeach swap meet but i don't think it's the right one. anyways any pictures will help.
Re: Anyone have power steering pump pic's
What motor?
http://www.scribd.com/full/17608177?...qy43h7a9pmdutn
I think you might be looking for this...on page 113
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
60-66 Nut
If your 283 still has the original short water pump, you will need brackets, pump and the pulley from a '68 and older car, or a '72 and older truck. Those parts can usually be found either on ebay or here on the forum in the '67-72 classifieds. The truck parts seem to be easier to find.
Here is one setup minus the pump http://www.67-72chevytrucks.com/vboa...d.php?t=474688 And here's a guy with just about every bracket imaginable..... http://www.67-72chevytrucks.com/vboa...d.php?t=439166
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 07-15-2011 at 12:59 AM. |
Here is a shot of the pump being installed:
1. from the drivers seat with the steering arm http://kieth.smugmug.com/Trucks/66-G...76075194_7Zf6Y 2. from the front: http://kieth.smugmug.com/Trucks/66-G...76075211_oopYL 3. Inner frame reinforcing plate: http://kieth.smugmug.com/Trucks/66-G...76075235_sCxRb this is the kit from classic chevy, cpp, etc.....did not know captaing fab at the time. Kieth ps power steering pump was from a 91 suburban 2 wd 1/2 ton. |
#9 | |
![]() Join Date: Aug 2005
#14 | |
#15 |
Nice. More info!!
You looking for the pump brackets on the motor or the PS box brackets on the frame. |
#16 |
#17 |
Who Me?
Nuttin fancy here, but it works.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
#18 |
So it's a 283 so no holes in the head then. Here's a bracket on ebay that might work.
http://cgi.ebay.com/ebaymotors/NEW-5...Q5fAccessories |
#19 |
Never Ending Projects
I used my '68 C10 bracket, which stock is a short water pump. In my '65 it was changed over to a long water pump. I was able to add three washers to the main part of the mount (where it attaches to the block) and cut and re-weld the rear bracket (where it mounts to the motor mount).
Not a great pic but you can kind of see what I did. Again, this was a stock '68 C10 bracket and pump. ![]()
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#20 |
#21 |
#22 |
What ever works. I looked on e-bay trying to see the diff and now i can spot it out. I'm missing the brackets & pullys i have everything else. Thanks Captain. lemme knose
#23 |
Take a look at http://67-72chevytrucks.com/vboard/s...d.php?t=453346. I used the bracket and pulleys from a 67, 68 283. I do have the short water pump. Check with Paul Duncan and son. He is a member here. http://www.pickupsandparts.com/Home_Page.html The bottom pic is my truck.
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate. Maintenance, repairs and upgrades on his dime now. http://zacks64longfleet.shutterfly.com/ Higher res. photos in my gallery. Last edited by ljackson; 07-20-2011 at 08:12 AM. |
#24 | |
thanks for posting it. I still need Captain fabs pulleys and that should fix my headache... haha |
#25 |
60-66 Nut
I've go the crank pulley and the '69-'72 pump bracket. I'll send you a PM on the price, so I'm not selling in this section
