Old 07-17-2011, 10:54 PM   #1
sav300
Severe wheel hop with new locker
I just finished a trans swap in my 70 3/4 ton and while I was at it I installed a detroit locker. Before the locker I could punch it, spin both most of the time, and not have any issues with wheel hop. Now when I do, it will hop extremely bad. Any clue as to why it's changed so much??
Here are the specs incase you need them:
3/4 ton with factory suspension
4L80E trans w/4000rpm stall
355 SB w/413HP
HO72 w/4.10s and locker
Weight is 3860lbs
LWB
32" street tires
This is my street/strip pickup and I am trying to get everything in oder to take it to the strip. This week I am getting new tires, but I would like advice on which shocks to get. Its about 80/20 street/strip.
Thanks,
Thomas
sav300 is offline   Reply With Quote
Old 07-17-2011, 11:36 PM   #2
BigDan3131
BigDan3131's Avatar
Re: Severe wheel hop with new locker
You said you just did a tranny swap from what to the 4l80e? Were your burnouts fine with the other trans and the locker or did you just do both at the same time. Can I ask why you went with a 4000 stall convertor on a motor making just 413HP?
BigDan3131 is offline   Reply With Quote
Old 07-17-2011, 11:58 PM   #3
sav300
Had a TH350 before and an open diff. They had no issues other than the trans having some bad slippage.
I bought the trans and converter together for a good deal and I am going to have an upgraded power plant going in that will put about 430+HP to the wheel with shift points at or near the 7,000 mark. So with the new set up the 4000 stall will work well.
Thomas
Old 07-18-2011, 12:00 AM   #4
sav300
And with the old set up both tires would spin most of the time. There were not many one tire friers.
Thomas
Old 07-18-2011, 10:25 PM   #5
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Thomas
how would both tires spin if you had an open diff?
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 07-19-2011, 04:04 AM   #6
sav300
clint
Not that hard. I've done it plenty of times. I have enough torque and the right gearing that made it easy. There are plenty of 50' marks to prove it too.
I'm still in debate about the shocks. Just got some Proxes tires ordered today. I've seen alot about Afco, any other ideas?
Thomas
