07-31-2011, 09:36 PM | #1 |
Newer rims to older truck
I am finding all kinds of rims on craigslist for the newer trucks and pretty cheap. Will the the newt 8 lugs fit my 82 8 lug. I do like the newer aluminum rims
2004 Silverado Crewcab (Dark Spiral Gray) |
07-31-2011, 10:10 PM | #2 |
Re: Newer rims to older truck
They should fit, pretty sure all 8 lugs are the same
07-31-2011, 10:46 PM | #3 |
They will fit. If you want to run the center caps you will have to purchase conversion lug nuts off ebay. The newer trucks have metric threads on them so you have to get standard lug nuts that are threaded for the center caps.
07-31-2011, 10:53 PM | #4 |
The threads are 7/16 right?
Here you go. http://cgi.ebay.com/ebaymotors/7-16-...s#ht_899wt_941 I guess maybe you have to contact him to get enough included for a 8 lug truck. |
08-01-2011, 12:42 AM | #5 | |
6.0 powered square
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
07-31-2011, 11:11 PM | #6 |
Even 4x4 ???
07-31-2011, 11:32 PM | #7 |
Yes, the lug nuts off the newer trucks won't fit your studs.
Posted via Mobile Device |
07-31-2011, 11:39 PM | #8 |
My studs on my 83 K20 are 9/16. Not sure about the rest of these trucks.
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400 |
07-31-2011, 11:55 PM | #9 |
all the old 8 lug are 9/16
1949 Five Window, 1973 Step Side, 2000 Z71 |
08-01-2011, 01:00 AM | #10 |
Chevys Kick A$$
Yep 9/16 sounds right for the 8 lugs. Let me know if you do get the new style rims on your truck curious to see how it turns out looking
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
08-01-2011, 07:46 AM | #11 |
backspacing is also a factor, newer wheels usually have too much backspacing, just depends
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
08-01-2011, 09:59 AM | #12 |
Oh ok, I wasn't sure what size the studs were. You will need lug nuts like that though. I would suggest contacting that seller for the correct ones.
