Old 10-06-2011, 12:23 PM   #1
C15_Sierra
C15_Sierra's Avatar
Air Intake Temp Sensor
I've read somewhere that you need this to run, but in pulling apart my harness, I discovered that there weren't any pins for it in the location specified (I have an Alldata printout). Harness is from an '00 Silverado 5.3, DBC
Can anyone shed any light on this? I saved wiring from other pins I had to take out, so its no big deal to install one...I just need to know if I definitely need it!
-Steve
1980 GMC C15 Sierra LWB
Dark Carmine Red/Carmine Int
Was: 250/3spd (1980-88), then a 305/TH350 (1988-2011)
Now: 5.3/4L60E, 2.73 12-bolt open rear
C15_Sierra is offline   Reply With Quote
Old 10-06-2011, 12:48 PM   #2
Robznob11
Robznob11's Avatar
Re: Air Intake Temp Sensor
Nope i have a 3"coupler from tb to mass and then a k&n o don't remember if i had one to delete when i did the harness mines 02 6.0
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 10-06-2011, 05:42 PM   #3
Shon
U need the IAT in any situation, wether its speed density or MAF use. Its used to calculate alot of things....
If you have a 5 wire MAF (5 wires going to MAF connector) then it has the IAT in the housing but you can relocate the IAT if wanted.
If its in the MAF then I would just leave it, there is no need to add more wiring...
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 10-06-2011, 07:14 PM   #4
C15_Sierra
C15_Sierra's Avatar
Thanks Shon
Turns out the wires were clipped to the MAF (which means I didn't get it with the harness) including the wire to the IAT which prob means it was there to begin with
-Steve
Old 10-06-2011, 08:44 PM   #5
Robznob11
Robznob11's Avatar
I stand corrected. lol I did not know that it was built into the mass. I just knew that mine does not have a seperate sensor that would be located in the in take tube like many you see in late model cars.
LED TAILS
