2000 5.3 silverado hard starting
Hi, my buddy has 2000 chevy with a 5.3 185k miles on it that takes 4-5 seconds of cranking to get it started and it stumbles a tad then idles normal. He replaced the fuel pump and fuel filter. Starts up fine i guess when its cold but not good when its warm??? A person autozone said the fuel pump still could be bad... Anyone got any suggestions? were stumped haha. Thanks in advance.
1979 C10 - swb, mild 327, restoration project 1979 Mustang - Turbo 5.3 / 4l80e 1976 K20 - Mild 396, 6" lift, 35's - sold 1986 C10 - lwb vortec 355- sold 1982 C10 - swb project- sold |
![]() Join Date: Aug 2004
Re: 2000 5.3 silverado hard starting
Do you wait 2-5 seconds after the key is turned to the on position b4 starting? Fuel pump needs to push fuel to tb.
Maybe dirty fuel rail too Posted via Mobile Device
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Yeah it starts just as hard whether we prime it or not so im thinking its not the pump. Could we blead the fuel lines pop the rails off and just spray them down good with carb cleaner and blow them out?
Has more rust than truck...
A bad new pump is possible, but check the fuel press regulator first. Its on the drivers side fuel rail. Pull the little hose off of the regulator, it there is any gas its bad.
x2
Name: Les ---------------------- Couple 80s Couple 70s One 68 ![]() |
Okay yeah we'll check that out cause someone previously had suggested that. Thanks!
Exactly how my dads 2000 suburban is except it has a whipple on it i've been wondering what it is though
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
one question on the regulator. If its bad and has gas in it, would that be when its running? off? or anytime? Thanks
Anytime
laying low
![]() Join Date: Mar 2001
#11 | |
ive seen them do this from bad carbon build up in the throttle body... Just pull it off and use carb cleaner to clean the build up off and run like a champ, check engine light even turned off
lots of good info here. Okay so no gas came out of the hose but symptoms seem about the same as Boog's. Could the reg still be bad if gas doesnt come out?
laying low
Gas coming from the regulator is an indication the diaphram is broken. The spring inside could possibly be broken I suppose. I don't recall it being all that expensive and it is easy to change.
One other thing I want to mention is the vacumn line going to the regulator. Take the top cover off the engine and look that line over real good too. Mine had a crack in the rubber elbow at the regulator causing a loss of vacumn. A new one from GM was $28. A big rip. Next time I'll use a plain piece of vacumn hose for 19 cents. ![]()
#15 |
I had this problem on my 2000 5.3 with the same hot and cold start symptoms. Everyone on this sight said fuel regulator, but i ignored it because it was replaced with a dealer fuel regulator a couple years ago when the problem first started, and the vacuum hose didn't have gas leaking out of it. Long story short I finally listened and bought another fuel regulator and it fired right up! 9 out of 10 times its your fuel regulator
1972 K20 lwb 2000 Z71 x-cab 1970 ford f100 |
#16 |
Sounds like its definitely either the hose or regulator. I'll tell him to quit being a cheap ass and go buy them haha. Thanks guys
#17 |
Sorry to bring up an old thread but to any who are wondering, it was indeed the fuel pressure regulator. took about 5 minutes to swap and the truck starts up great everytime now. Thanks everyone for the help
#18 |
laying low
It's always good to hear back on what the fix was. Glad to help.
#19 |
Thanks for the help boog
