do i have positrac
i have 1997 chevy truck ahs 14 bolt rear end in it today i hold the brake while pressing the gas i got out looked at the ground there was 2 tires marks what does this mean
woudl this be posi
whould this be a posi rear end
Got dropped
Re: woudl this be posi
No that would be black top
93 Chevy C1500 Sport 4/6 Drop, Black and Red Int. 00 K1500 ECSB Z71 Stock Daily Driver w/18" Z71 Wheels |
Thats cruel^ lol and the burnout means nothing just that both tires broke loose, i dont have posi and sometimes ill get both tires breaking loose, just depends on the conditions.
I tear it up... -90 Chevy 1500 355 edelbrock - sold ![]() -90 1500 reg cab 350 5 speed - current http://tinyurl.com/c7b7rvy Plan for the worst , Hope for the best, keep the guys next to you safe, and you'll come out on top. -Hooah |
One day...
![]() Join Date: Apr 2008
Re: do i have positrac
One day...
Very possible, put the truck on stands and rotate one wheel fast and if it grabs and starts to turn the other then it has a gov-loc in it, if so i wouldnt power brake it anymore or it will grenade.
Newbee
^^ What he said^^
Another name for them is Gov Bomb. If you beat on it, you will find it's limits. |
well i also stoped at the stop sign pressed on the gas hard around the corner sure enough 2 tire marks again
One day...
Moderator
![]() Join Date: Oct 2008
I think the gov bomb is RPO G80 on the SPID label.
The gov-loc in the 14-bolt is a completely different animal than the one in the 8.5" gov bomb. If it's a gov-loc, it will unlock before you get a lot of wheel speed, they're not designed to lock 'em both up all the time, just with different wheel speeds and only to a certain axle speed. After that, the counterweight swings out and unlocks it. That's why they suck for racing. I think that's what you have. An open diff will spin 'em both at times, but the road needs to be slick/wet.
Get the last 8 digits of your VIN, a parts counter guy at your local Chevy dealership should be able to look it up and tell you. |
well in my glove box it says gu6 and g80 but that it when it had the 10 bolt rear end in it someone changed the rear end in it out of 1992 chevy 3/4 so now it has that 14 bolt rear end so u think it has g80 in it
