Old 02-17-2012, 06:18 PM   #1
81ratrodc10
house of chevy's
81ratrodc10's Avatar
Angry oil leak?
So on my way home from work today i kept getting a burning oil smell so i got home opened the hood to find the area around fuel pump and such pretty socked in oil i catn really look at it till tomarrow my first thouhht is oil pan gasket if so how hard r they to change or if anyond thinks its something else please let me know
1987 m1028 cucv d30
2001 chevy s10
2000 honda shadow sabre 1100
"it's going to be an interesting ride home"
81ratrodc10 is offline   Reply With Quote
Old 02-17-2012, 07:13 PM   #2
rwhit57
rwhit57's Avatar
Re: oil leak?
The fuel pump gasket to the block could be leaking, or maybe the timing cover. If it was the pan gasket I would think it would be all over the bottom, not up around the fuel pump. Just an idea. If it's dropping down on the exhaust it could just be valve cover gaskets.
"Whoever said money can't buy happiness has obviously never seen a speed shop!
rwhit57 is offline   Reply With Quote
Old 02-17-2012, 07:29 PM   #3
81ratrodc10
house of chevy's
Re: oil leak?
How hard is it to change the timing cover gasket
1987 m1028 cucv d30
2001 chevy s10
Old 02-17-2012, 11:31 PM   #4
donut
donut's Avatar
Re: oil leak?
IMO, timing cover is more of a pain than the oil pan, in fact, if I were going that deep, then I'd do the oil pan also.
Personally I'd look closely at the fuel pump to block gasket. There is a plate that goes to the block and then the fuel pump.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 02-17-2012, 11:41 PM   #5
rcbildr
rcbildr's Avatar
Re: oil leak?
IIRC there is a bolt hole/boss on the front of the block that is right in line with the fuel pump push rod. On some blocks, that hole goes all the way thru to the push rod and can leak oil. My friend had that problem just after he built a 383. Once he put a bolt in there, no more leaking.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 02-18-2012, 12:37 AM   #6
bowtiemanchevyman
bowtiemanchevyman's Avatar
Re: oil leak?
it sound like the the gasket for the fuel pump. there are two gasket. and not the timing cover if it was th timing cover it will run down the front and go under not to the fule pump area. The pump should only take like 30 min it u know the little trik to keep the push rod up in the motor. There is a bolt on the front of the motor that plugs a hole its right by the fule pump pull it out and put on in that is a little longer and it will hold the rod in place when u are done put the old one back in. and you are done.
bowtiemanchevyman is offline   Reply With Quote
Old 02-18-2012, 07:04 AM   #7
81ratrodc10
house of chevy's
Re: oil leak?
Were is this bolt anyone have a pic
1987 m1028 cucv d30
2001 chevy s10
Old 02-19-2012, 11:22 AM   #8
Gibson
Gibson's Avatar
Re: oil leak?
http://www.rowand.net/Shop/Tech/Myst...evyOilLeak.htm
Check that link out for a pic and description.
Gibson is offline   Reply With Quote
Old 02-18-2012, 10:07 AM   #9
81ratrodc10
house of chevy's
Re: oil leak?
Over the summer i took out my ac braket from the front of the fuel pump never put the bolts back in the holes there u think thats were it is comin from y would it take this long for me to notice it
1987 m1028 cucv d30
2001 chevy s10
Old 02-18-2012, 12:36 PM   #10
bowtiemanchevyman
Re: oil leak?
the bolt it on the front of the block on the ame side as the pump right next to the pump. its not hard to find. if u look at the front of the block its right above the oil pan and next to the fuel pump. its not hard to find
Old 02-19-2012, 07:45 AM   #11
81ratrodc10
house of chevy's
Re: oil leak?
Well i put two bolts back in the ac braket wholes cleaned the are real good added oil back let it run drove it around let it run some more and its still clean i have no idea im at a loss i had to add 3 qts of oil back in
1987 m1028 cucv d30
2001 chevy s10
Old 02-19-2012, 04:48 PM   #12
81ratrodc10
house of chevy's
Re: oil leak?
Thank you that is the top bolt location were my ac braket was ill keep an eye on in in the next few days and see if that was really the prob u guys r great
1987 m1028 cucv d30
2001 chevy s10
Old 02-25-2012, 12:10 AM   #13
BigJackDaddy
BigJackDaddy's Avatar
Re: oil leak?
<snip> the area around fuel pump and such pretty socked in oil </snip>
What else had oil on it? Fuel pump and... motor mount?
Without a picture it's hard to tell but I'd start by checking the valve cover gasket above the fuel pump. Wipe the area above the pump with a rag and see if it's oily. Gravity works.
ColoradoMelons.com
BigJackDaddy is offline   Reply With Quote
Old 02-25-2012, 07:02 AM   #14
81ratrodc10
house of chevy's
Re: oil leak?
Well its not leaking oil but now you can check out the new thread were to buy dynamite
1987 m1028 cucv d30
2001 chevy s10
