Old 05-05-2003, 01:18 PM   #1
TIMSPEED
TIMSPEED's Avatar
How hard would it be to lay rocker?
How hard would it be to actually get as low as my truck in my avatar? I KNOW I'd have to completely remove the front/rear fenderwells, but I mean other than that...wouldn't I need to somehow raise my tranny crossmember and probably my front crossmember, as they're the only two things that are below my rocker line (other than my suspension, of course)
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 05-05-2003, 01:50 PM   #2
low 84
low 84's Avatar
just like you said. anything tahts below the rockers has to get raised. and you'll need the bed cut open and probly at least a 10 inch notch
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 05-05-2003, 01:55 PM   #3
TIMSPEED
TIMSPEED's Avatar
But hot damn doesn't it look bad as hell layin rocker like that! Maybe I should just concentrate on getting a paint job first. :p
See Them Here
Old 05-05-2003, 02:23 PM   #4
BaggedC10
Under construction!
BaggedC10's Avatar
You can lay rocker with a 10" step notch, raised front cross-member, and removed/custom wheel houses.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 05-05-2003, 03:58 PM   #5
2tankin79
2tankin79's Avatar
.. body drop
2tankin79 is offline   Reply With Quote
Old 05-05-2003, 04:18 PM   #6
low 84
low 84's Avatar
gotta have custom tranny cross member too
'05 1500 Crew Cab
RIP
Old 05-09-2003, 07:18 PM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Hmm? Let me think here. The front crossmember has to be replaced, modded, or raised. The tranny crossmember can be flipped above the frame. The e-brake cable/brackets hang down. The exhaust crossover is way to low too.
Beyond that, plan to cut and super C the frame and bed. That's a good starting point anyway. Then you can plan on spending 2k on air suspension.
This is where you start...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-11-2003, 03:09 PM   #8
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
oK, even after you flip your tranny cross member, raise the crossmember, move the gas tank, use tubular upper and lower control arms, raise the steering - you still are only going to lay frame. Trust me, I have doen all these things, and my truck lays flat on the frame - which puts the rockers about an 1-1/4" off the ground. Also - I'm running a 9" notch in the rear on a 27" tall tire and I have about 3-4" left before the axle hits. So really no need for that 10" notch at all, unless you really want to tuck some huge meat.
chuck
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 05-11-2003, 04:14 PM   #9
Nvbowtie
Nvbowtie's Avatar
Here is a close one to your picture you fabricated....
www.unlimited2u.com/chevy
1980 Chevy C-10 Silverado
1988 Chevy Blazer Tahoe
Nvbowtie is offline   Reply With Quote
Old 05-11-2003, 04:51 PM   #10
CustomChevy
Unfortunately, you will absolutely have to do a body drop to lay rocker. The frame under the cab extends below the rocker. (also, the other items previously mentioned)
Purely for safety reasons, you should only drop it to the point that when fully lowered, you still have room to drive it, even with the tires flat. You never know when something really shi*ty will happen. Just some advice.
post some pics when you slam it!
CustomChevy is offline   Reply With Quote
