Old 03-27-2012, 08:53 PM   #1
gilley
gilley's Avatar
turndowns at cab
Thinking about putting turndowns on my truck, but only running them to the cab and not out all the way... i was just wondering if anyone had some pictures of what they might look like. Thanks
70 chevy cst-10
huggar orange
chevy 350
gilley is offline   Reply With Quote
Old 03-27-2012, 09:12 PM   #2
rob32472
Re: turndowns at cab
I have no pics but the "drone" will kill the interior
rob32472 is offline   Reply With Quote
Old 03-27-2012, 09:25 PM   #3
gilley
gilley's Avatar
o will it really? what about it you stop about where the bed starts
70 chevy cst-10
huggar orange
chevy 350
Old 03-27-2012, 09:32 PM   #4
gcburdic
Restoration Virgin!
gcburdic's Avatar
here's mine....it does drone, but that lumpy cam sound just makes it so hard to run a full length exhaust system sometime (although I am considering it)
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 03-27-2012, 09:31 PM   #5
67c10rustbuket
67c10rustbuket's Avatar
I had a 69 years ago and I did this, after blasting and coating my full length tri-y thorley headers I took some flowmaster mufflers and header collectors to an exhaust shop and told them I need 18" between them. Well I couldn't hear myself think much less a radio in that thing, it was loud! I traded it to a friend and the first thing he did was put a full length exhaust on it. I may have a pic somewhere, ill see if I can find one for you.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 03-27-2012, 10:26 PM   #6
heidick70
heidick70's Avatar
i also have this on my truck sounds alright outside, but inside i about go crazy from the noise
heidick70 is offline   Reply With Quote
Old 03-27-2012, 10:54 PM   #7
sir_talk_alot
sir_talk_alot's Avatar
though not on a chevy, my daily driver dodge with the 318/5spd has straight 2 1/2 under the cab, the drone gets old, but around town, its tough sounding. thank god for subs, they help cover the sound to some degree. i can sure get some heads to turn, i can play with corvettes/camaros/stangs with pipes and they chuckle to hear a truck next to them. ive even messed with harleys, sure does surprise them when they are cruising the interstate and i roll up next to them and drop gears, they look to see whats making the noise. if i were you and what im going to do on my 10, is dump it in between the front of the bed and the rear end. that way it sounds good, but doesnt annoy you on a cruise.
-Mike-
'94 GMT 400 ext z71 3" body, 3 in rough country, hd mirrors, 20" motometals on 35s
sir_talk_alot is offline   Reply With Quote
Old 03-27-2012, 11:27 PM   #8
gilley
gilley's Avatar
i love that look gcburdic!! Right now I have longube headers with glasspacks out the back and they turn outwards at a 45 degree angle.. how much louder do you think under the cab will be?? a lot or not that much.. It doesnt really matter to me how it sounds on the inside I just want the look and also a good sounding loud exhaust
70 chevy cst-10
huggar orange
chevy 350
Old 03-28-2012, 12:30 PM   #9
gcburdic
Restoration Virgin!
gcburdic's Avatar
Thanks!!! these are long tube ceramic headers from summit racing, into those mesh looking pipes (used to align it under the truck better), into an H-pipe, into Flowmaster 40's, out to turn downs....truly, I have gotten use to the drone and it really doesn't bother me....the engine has a very nice lumpy cam so it sounds so gooooood! Not sure how glasspacks would sound, but assume it'll have a different sound/drone
Geoff with a G
Old 03-28-2012, 12:54 PM   #10
specialtyretail
So,, what else you got???
specialtyretail's Avatar
I really like hearing a healthy engine,,, but,, on a long trip it might a little tiring. Noise can wear on you like hard work can,, just beats you down after a while.
specialtyretail is offline   Reply With Quote
Old 03-28-2012, 09:01 PM   #11
gilley
gilley's Avatar
i might just end up runningthem to the front of the back tire but just wanted some input about under the cab.. so thanks for the help guys
70 chevy cst-10
huggar orange
chevy 350
Old 03-28-2012, 09:04 PM   #12
rob32472
use dynamax vt mufflers they are designed specifically to reduce drone......
Old 03-29-2012, 12:41 AM   #13
AustinScott
AustinScott's Avatar
under the cab...... yeah..... it is great in theory... but if you drive your truck a lot you will find yourself always thinking about how loud it is...
I had mine dumping right under the cab, no turndowns.
I had to put some 90's on after the mufflers and point them to the side of the truck to even think about enjoying the ride.
Currently have it all redone exiting right in front of the rear tires..
I think they are perfect, loud when you want them to be, but they don't bug you while cruising on the freeway.
BEFORE
AFTER
Hope this info helps you decide, good luck... in the end, its your truck so build it to fit "your" needs!
-=Scott=-
68-SWB, 327, hooker headers, spintec mufflers, disk brake 3.5/5 drop, buddy buckets, 200-4R, 2200 stall, 3.73 12bolt Eaton Posi,
My 68-SWB Photo Build Thread
All my Google Albums
AustinScott is offline   Reply With Quote
Old 03-29-2012, 12:53 AM   #14
JointTech
JointTech's Avatar
whats that cross piece for?
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 03-29-2012, 06:40 AM   #15
gotchevys?
gotchevys?'s Avatar
On my 70 swb I welded sleeves through my cross member and ran headers with 3" pipe to a set of Super 44s with turn downs right behind them. I had no problem at all with interior sound.
Here is the best picture I could find.
www.fatdaddieshotrods.com
gotchevys? is offline   Reply With Quote
Old 03-29-2012, 08:25 AM   #16
I love the sound of a healthy engine. I think they sound best,no matter how long,when they exit out from under the body. Get's the fumes away,too. I'm not into carbon monoxide. I don't like the reverberating sound made by dumps up under the body. I would never run any exhaust any shorter than at least back "past" the cab for the sake of safety and health.I've heard many a 500+ 3" exhaust car with full length exhaust that you know are bad from the sound way down the block. Anywhere on the side sounds way baddass compared to straight out the back. Something about separating the sound from each pipe gives a more radical sound to me. Straight out the back smooths it out and puts it behind you.
