Old 03-28-2012, 12:41 AM   #1
Touchdown67
Touchdown67's Avatar
To keep the E-brake or not?
I am putting a 700r4 in my 65 C10 and came across the dilemma of keeping the E-brake or not. Since the stock crossmember had to be removed I don't know if we should take the time to make a new shorter set up or ditch the whole E-brake entirely? Since I will have the automatic with park I guess it really isn't needed. Has anyone done this exchange and had the same idea?
Touchdown67 is offline   Reply With Quote
Old 03-28-2012, 12:48 AM   #2
Slow Build
Slow Build's Avatar
Re: To keep the E-brake or not?
I think you can just switch to the 66 setup. It doesn't use the crossmember if I remember correctly.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 03-28-2012, 01:00 AM   #3
losthope
losthope's Avatar
ya i would just pull one out of a 66' heres a link to "woogeroo's" web page section showing 8 pictures of the set up all cables basically and a couple hooks, you have to click each photo one by one:
http://woogeroo.home.mindspring.com/...2/brakes2.html
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 03-28-2012, 01:27 AM   #4
Captainfab
60-66 Nut
'66-'72 use the same basic e-brake cable assembly, without a crossmember as the '63-'65's did.
Old 03-28-2012, 02:09 AM   #5
Touchdown67
Thanks for all the help. I will look into keeping the brake.
Old 03-28-2012, 07:17 AM   #6
T Smith
T Smith's Avatar
Thanks for that link, that's just the pics I've been wanting to see!
T Smith is offline   Reply With Quote
Old 03-28-2012, 01:00 AM   #7
Rooster's 67
Rooster's 67's Avatar
Your state doesnt require a safety inspection but personally I would keep it but I might be inclined to change it to a pedal op instead of the hand.
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 05-28-2012, 10:46 PM   #8
wmbige
Hey,
I am trying to go to Waterloo site, and it doesn't work. i need info on fixing my parking brake on 1965 Chev truck.
Wmbige
wmbige is offline   Reply With Quote
Old 05-28-2012, 10:47 PM   #9
wmbige
I mean woogeroo
