Old 05-08-2003, 04:44 PM   #1
68Custom
Hammer On!
68Custom's Avatar
Unhappy Front End
Im just curious, i had my front end rebuilt last november and ive noticed an awful lot of squeaking on the control arms and such... all the zerks that could take grease are greased, steering parts are all greased too, anyone else having this problem? I tried some of this liquid silicone stuff from Oreilly but that helped for like 2 days or so.... any advice? ideas? thoughts? Im guessing its the u bolts rubbing on the arm shafts or the bushings could be, i thought about marine grease on the bolts/shafts, oh well thanks for the help!
Aaron
1968 C20
Inline 6 250
SM465 4 speed
1968 K10
Inline 6 250
SM465 4 speed
68Custom is offline   Reply With Quote
Old 05-08-2003, 08:24 PM   #2
MOTHERTRUCKERS
Did some zerks not take grease? Are the cap nuts tight on the control arms? Are the u-bolts tight?
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 05-08-2003, 09:25 PM   #3
adamls
Gotta Startem Early
adamls's Avatar
Are you using Poly or rubber? I have heard that the silicone on poly only makes it worse.
67 SWB In Progress, one piece at a time, maybe 3 years I will be finished
adamls is offline   Reply With Quote
Old 05-08-2003, 10:09 PM   #4
68Custom
Hammer On!
68Custom's Avatar
yeah everythings checked out tight but ill go check 'em out again to be double sure, using rubber as far as the bushings go.....
Aaron
1968 C20
Inline 6 250
SM465 4 speed
1968 K10
Inline 6 250
SM465 4 speed
Old 05-08-2003, 10:42 PM   #5
slam33
slam33's Avatar
The only bushing that could be rubber or poly are going to be the sway bar bushings. The control arm bushings are metal, with a rubber seal on the inside of the arms. check your shocks and sway bar bushings. If your sure the squeek is off the front end, the check your rad support and cab mounts. It could be off the rear, which would be the control arms or panhard rod if you have coils or the leaf spring bushings if you have those.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 05-09-2003, 12:49 AM   #6
68Custom
Hammer On!
68Custom's Avatar
good point slam, the swaybar bushings are brand new from the rebuild, however any mount bushings for the body are shot as far as i know. the front end body will have work done sometime down the road. i am most certain its coming from the control arm shafts, ill do some checking again in the morning to see whats up, thanks!
Aaron
1968 C20
Inline 6 250
SM465 4 speed
1968 K10
Inline 6 250
SM465 4 speed
Old 05-09-2003, 06:39 AM   #7
ZOOMY
squeak
My guess is the control arm bushings......Zoomy
ZOOMY is offline   Reply With Quote
Old 05-09-2003, 10:48 AM   #8
OhioDan
OhioDan's Avatar
Is your control arm shaft caps screwed in to tight, or maybe the shaft is to far forward, or to the rear, bottoming out in the cap? Just my $.02
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 05-09-2003, 12:13 PM   #9
Stroker
I've been wondering about the same thing. After rebuilding my front suspension I wasn't able to get the grease to pass thru to the rubber grease boots on the back side (upper and control arms lower torque tube and cross shaft). I checked to be sure the bushing were not bottomed out on the shafts by removing the grease zerk and inserting a paper clip into the hole till it bottomed on the shaft. I tought maybe there has to be some wear on the theads of the shaft and bushings before the grease will make it thru. In my case both were new.It will be a while before mine is on the road. Maybe someday.
72 SWB parts and pieces
Oklahoma
Stroker is offline   Reply With Quote
