Old 05-09-2012, 01:30 PM   #1
BrookelynnGreen
BrookelynnGreen's Avatar
Tire Sticking Out
I have an 86 chevy pickup, and the front driver side tire sticks out. All the other tires are fine, but this particular tire sticks out. I "believe" it could be the bushings. Is there anything I really need to check that may cause the front driver side tire to stick out? Please help. Thank you.
-Samuel
"Knowledge Is Power"
BrookelynnGreen is offline   Reply With Quote
Old 05-09-2012, 02:56 PM   #2
ont_guy_38
ont_guy_38's Avatar
Re: Tire Sticking Out
You sure all the rims are the same width and backspacing , not unusual for the wrong part to get in the right box at the factory
ont_guy_38 is offline   Reply With Quote
Old 05-09-2012, 02:58 PM   #3
BrookelynnGreen
Can you please tell me how I can check that? When I bought the truck the rims were already on it. So I'm not sure.
-Samuel
Old 05-09-2012, 03:22 PM   #4
hartbraker
If there is any way to stick a tape measure through a hole in the rim I'd suggest that and measuring to check the width in comparison to another rim. Backspacing you can check from the back side of the rim. Measure the distance from where the rim is bolted to the hub to the inside lip of the rim (where the tire is seated on the bead). Then check that measurement in comparison to another rim... It's likely a backspacing difference, but I've been known to be wrong.
Good eye though catching the difference.
1986 Chevy Silverado k30: factory air, tilt wheel, 454cu 7.4L, Turbo 400, NP205, Corporate 14 bolt, Dana 60 front, 4.10 gears, SRW, long bed, standard cab... MY TRUE LOVE
hartbraker is offline   Reply With Quote
Old 05-09-2012, 03:21 PM   #5
Pro Performance
Pro Performance's Avatar
You measure from the mounting surface, where it bolts up to the hub (rotor), to the very back edge of the wheel.
To check width, do the same thing, but to the front side. All wheel measure about 1" wider than that they advertise it at, this is due to the bead. But in your case, this is just for a point of reference, so it will be Ok.
- Travis
Pro Performance is offline   Reply With Quote
Old 05-09-2012, 05:32 PM   #6
BrookelynnGreen
Could the front tire stick out because of something in the suspension that maybe went bad??? (this is super irritating!!!)
-Samuel
Old 05-09-2012, 06:30 PM   #7
jrcaprai
Just curious, what does the other side look like?
jrcaprai is offline   Reply With Quote
Old 05-09-2012, 06:34 PM   #8
BrookelynnGreen
The other side looks exactly like the other 3 tires. All 3 are tucked in. Just this front tire sticks out.
-Samuel
Old 05-09-2012, 07:10 PM   #9
Goldfinger
Goldfinger's Avatar
Is there a spacing plate behind it
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 05-09-2012, 07:18 PM   #10
Firebirdjones
Pull the front wheels off and swap side to side real quick...that will answer your wheel questions.
Firebirdjones is offline   Reply With Quote
Old 05-09-2012, 08:35 PM   #11
makman1297
makman1297's Avatar
You could check to see if the distance is the same from the frame out, maybe the body or fender are shifted to that one side.
1981 Dodge D-150 (under construction)
2007 Chevy Suburban
2010 Dodge Charger R/T
1980 Kawasaki KZ 440
2004 Harley Sportster 1200
makman1297 is offline   Reply With Quote
Old 05-09-2012, 10:58 PM   #12
BrookelynnGreen
So I took my tire off and inspected, I think they are my tie rod ends, they are squashed.. Coulld that be the problem? Could the rotor be different?
-Samuel
Old 05-10-2012, 11:37 AM   #13
Firebirdjones
I've had an instance where a cheap chinese made rotor did have a different offset on the front of a grandprix. I've never seen that problem on anything else since (it's been years) but I guess that could be a possibility.
If you swapped wheels and still see the offset (which looks accessive to me) I'd say you have something going on because all the trucks I've owned never had a difference from side to side.
Could be that thing was in a front end collision too, and things just weren't straightened properly during the repair.
Old 05-09-2012, 11:20 PM   #14
Pro Performance
I wouldn't think that would be it. I would take a picture of the other side, so we can see what that looks like for comparison and how much of a difference it is.
I would put the front on jack stands and make sure it is level, then take both wheels off. From there, tie a few washers onto a string and hang it from the outside fender lip. Measure from the mounting surface on the rotor, to the string..... and see if both measure the same.
I am sure it might be off a hair due to production tolerances, but should be close.
Old 05-10-2012, 08:56 AM   #15
1bad87
1bad87's Avatar
they all stick out on the driver side only i notice that a long time ago
1bad87 is offline   Reply With Quote
Old 05-10-2012, 08:57 AM   #16
1bad87
1bad87's Avatar
my tire keep rubbing the fender on the driver side only and notice it stick out and the other 3 are well tuck in
Old 05-10-2012, 06:40 PM   #17
silvereagle07
silvereagle07's Avatar
I think 1bad87 is on to something. I noticed all of my squares in the yard stick out on the drivers side. It's really noticeable on my slammed 84 GMC.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 05-11-2012, 10:46 AM   #18
crazeetxn
crazeetxn's Avatar
This may play into our favor when we're trying to buy one "Uh, somethings wrong with your tire here....may need to take $500 - $1000 off cause I'm gonna have to fix that"
1st - '68 long bed
2nd - '81 SWB
Now - '86 SWB, Edelbrock 1406/stock 350/700r4
crazeetxn is offline   Reply With Quote
Old 05-10-2012, 06:47 PM   #19
1bad87
1bad87's Avatar
is it a bad thing? they all are like that from dealership
Old 05-10-2012, 08:13 PM   #20
Firebirdjones
Mine aren't....what are you guys drinking?
Old 05-10-2012, 08:49 PM   #21
rwhit57
rwhit57's Avatar
Mine neither. That just doesn't make sense.
"Whoever said money can't buy happiness has obviously never seen a speed shop!
rwhit57 is offline   Reply With Quote
Old 05-10-2012, 07:07 PM   #22
Prerunner1982
Prerunner1982's Avatar
Just for the record here is a picture of how to measure back spacing. I realize we are beyond this now, but for anyone new who may be reading it.
I may look at my 82 when I get home to see if it has the same issue.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 05-10-2012, 08:56 PM   #23
'82 steppin
'82 steppin's Avatar
Ok thats weird mine sticks in little bit !!!
'82 steppin is offline   Reply With Quote
Old 05-10-2012, 11:06 PM   #24
Firebirdjones
Old 05-11-2012, 08:22 AM   #25
Keith Seymore
Keith Seymore's Avatar
The front fender to hood gap is set by scooting the radiator support/front clip side to side. If the cab is not set on the frame straight (ie, square) in the plan view then the hood shoots off to the offending side, and the front end is scooted to that side to accomodate. The result is that one tire could be sticking out, and the gap from the fender to the bumper will be tighter on that side than the other.
I don't think that's the case here, since:
a) Only the one tire is sticking out. The other tire would need to be "overly tucked in" (or "sticking in") the same amount, and nothing was said about that.
b) Nothing was said about uneven gaps between the fender and the bumper.
Not "all" trucks do this (mine does not). It was particularly senstive on regular cabs, due to the short length; conversely it was never really a problem on Blazer/Suburban with their comparitively long bodies.
Sounds like a chassis/wheel issue to me.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
