Swapping the 4.3L to a RamJet 350 predicament
First of all i must say i love this website, when i began my frame off i knew nothing about these trucks, and now i know where every damn bolt goes. So i want to thank everyone for the help. So heres my latest situation. Ive got the frame rolling and now its time to put the drivetrain in. Im getting a killer deal on a RamJet 350 ($5500.00)so im curious if the bellhousing on my sm465 transmission will bolt up to the new v8 engine and also i dont know if the engine mounts will have to be moved forward, back, or hopefully stay in the same shape? Ive been searching the forum like crazy and i havent found any solid info yet. And i know this really has nothing to do with my post but N2TRUX ramjet setup is beautiful, im sure everyones already seen it but wow great looking truck.
1986 GMC K15 4.3V6/SM465/NP205 will be converting to 5.3LS E-ROD/AA adapter/SM465/NP205 10 Bolt Axle Rebuild Tutorial: http://67-72chevytrucks.com/vboard/s...d.php?t=536415 |
Re: Swapping the 4.3L to a RamJet 350 predicament
as far as i no they are all the same expete the l6 the monts have to move for those i think. the bells should also be the same if not there are a ton of those trans out there and you can get one ez same as fly and clutch
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
You just solved all my problems thank you, ill go ahead and order the engine.
BAD BOW-Silverado XST
A 4.3 has the same bolt pattern as a 350 SB. It's a direct swap. All accessories will fit too. Motor mounts will also swap. Basically, you're adding two cylinders.
Please explain further concerning the engine mounts; Can the frame mounts and engine mounts be re-used and in the exact same positions?
Yes. The 4.3 is just a v8 less the front 2 cylinders. The mounts are all the same including acc.
___________________ 78 ccsb dually 5.3 4l60e http://67-72chevytrucks.com/vboard/s...d.php?t=491551 |
At the body shop.
You may need a flywheel. I think a ramjet come with a flexplate
" That didnt make it any newer " " Dont antique the equipment " |
#8 | |
Good point. I'm not sure how the 4.3 flywheel is weighted.
#9 | |
Happy to be here
![]() Join Date: Mar 2000
