tips before I pull my engine and trans. ????
My neighbor borrowed me his engine hoist with leveler last night so I will be pulling the engine and trans out of my 81 shorty in the next few days. I want to pull the engine and trans all together if I could. The front clip is on the truck and prefer not to take it off right now if I don't have to. I have the drivers side exhaust manifold off and the passenger side has only the far rear bolt in it that I can't seem to get out although there is only a few inches of actual exhaust pipe on the end of the manifold. I unhooked most of the stuff and have removed the carburetor........ Any and all helpful tips would be greatly appreciated.
Thanks in advance, RIZ ![]() |
yeller
Re: tips before I pull my engine and trans. ????
Drain the transmission, because you will lose fluid once the driveshaft is removed and you start removing the assembly.
Take off the hood, remove the radiator. Get a helper. Have a place to store the engine/trans when removed, I wouldn't leave it hanging from the houst or just sitting on the floor. Have lots of rags and cleaning supplies handy to clean up the mess you are about to make ![]()
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#3 | |
Robert Olson Transport
![]() Join Date: Oct 2002
at least one helper its heavier than it looks make sure you put the truck on jack stands high so you have the room to swing the motor and trans I try to put a dam up with the rags for the fluid because no matter how much you drain there is always more than youve let out once you start disassembling things make sure you put things in labelled bags where they go back and photograph things for future refrence I try to use pieces of masking tape and write numbers on them for the wiring harness so plug 1 goes on sender 1 2 goes on 2 etc etc makes it easier to figure out even if youre putting in a totally different engine
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
Plastic baggies for nuts and bolts.
GM Addicted
To make life easy I always take off the front clip not hard to do at all. Yes it is a little more work but well worth it to have the room.
![]() ![]() 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
take a million detail pics of everything before tear down, and all fastners/brackets should be bagged and labeled
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
![]() Join Date: Oct 2009
Ziplock bags, black sharpie, kitty litter for any mess on the ground. Remove fan, shroud, radiator. Floor jack under rans helps while pulling every thing out. Make sure e-brake cables dont get caught on trans. Good luck and have fun.
Cover your intake with duct tape so you dont drop stuff in there. Sharpie and zip lock bag all nuts and bolts. For sure take a few photos of it before removal, helps remember where lines/brackets/hoses etc. are at.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
Newbee
X2 on kitty litter/oil dry, lots of it! A transmission snout plug will save you alot of grief too.
Make sure the bolts that are holding the engine to the hoist are quality bolts, threaded in deep, and seated against the lifting device. And what everybody else said. |
I removed my front tires and lowered the front axle on a set of blocks. This was the only way the engine/trany&t-case would clear the front radiator support bracket. It made it alot easier hooking everything up to the new engine.
![]() Join Date: Mar 2009
Cool thread ...
Big piece of plywood screwed to a set of sawhorses to spread out all your stuff. Also, the next time I do this Im gonna make sure I've got enough extra shop time to clean-up and detail the engine bay while the motor is out. Posted via Mobile Device
'80 SRW C35 - 355/700R4/4:11/2.5-3/DD '77 Cheyenne K5 - Roller cam 355/NV4500/205/4:88's/35's/DD rust repair on the '77 http://67-72chevytrucks.com/vboard/s...d.php?t=740291 |
