Old 05-26-2003, 06:54 PM   #1
pat
pat's Avatar
How do I remove my dash bezel?
I took all the screws out, and the bottom is loose. But the top of the bezel seems to be catching on something. Do I need to unhook something else?
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s
64 Cadillac Sedan DeVille
pat is offline   Reply With Quote
Old 05-26-2003, 07:00 PM   #2
special70gmc
special70gmc's Avatar
the chrome bexels around the lights and wiper have to come off. sticl some neddle nose pliers in the flat spots and spin them off just like a screw. -kyle
1986 c-10 swb 5/7 drop 20'' coys
1958 belair 2door
special70gmc is offline   Reply With Quote
Old 05-26-2003, 07:01 PM   #3
Slams_58
need to unhook the oil psi switch, wiper knob, light switch along with the chrome rings around them, and the speedo cable
Slams_58 is offline   Reply With Quote
Old 05-26-2003, 07:02 PM   #4
9teen69
9teen69's Avatar
Don't just keep pulling like me... take of the speedo cable and the oil pressure line.
72 Cheyenne SWB C10 (daily driver)
(Super fake cause I just love the glovebox emblem)
70 Camaro RS (frame-off in pieces)
70 Camaro RS (daily driver backup)
69 Custom LWB C10 (son now drives)
9teen69 is offline   Reply With Quote
Old 05-26-2003, 07:48 PM   #5
70cst10_05
70cst10_05's Avatar
don't forget the wires that plug into the back
1970 Chevy CST/10
1970 Chevy CST/10
1972 Chevy C/10
1972 Chevy Suburban K/10
2019 Silverado 2500 Duramax
Kevin
70cst10_05 is offline   Reply With Quote
Old 05-26-2003, 10:48 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
LOL!!! I can laugh becouse I been there!
Old 05-27-2003, 04:34 AM   #7
Seke69
Space Cadet
Seke69's Avatar
I've done that twice!
a few things to get caught up on...
the chrome bezels around washer and lights
the speedo cable
the oil pressure cable/line(the one I forgot about twice!)[also did you know that the 'U' in the word 'custom' from the side badging will work as a wrench to get the oil p line unscrewed?!]
the steering column retainer thing (under column)
there's something else but I can't think of it now... good luck.
Seke69 is offline   Reply With Quote
Old 05-27-2003, 10:11 AM   #8
pat
pat's Avatar
Thanks. I want to take it off and try to repaint it myself.
Old 05-27-2003, 10:22 AM   #9
Mike Culpepper
Red
Mike Culpepper's Avatar
I did this just this weekend for the first time. These guys know what they're talking about. You also must remove the headlight knob/shaft before you can remove the headlight switch bezel. SOmething I don't know if I would have thought about if I hadn't read on this board, is to disconnect the neg. post on the battery before doing all of this or your headlights will be on while your doing the bezel removal. To do this reach up behind the dash and feel for a button on top of the headlight switch. Push this down as you remove the knob/shaft. Then you can unscrew the bezel. On mine there was also a small light bulb assembly with a wire going to it that ended in a metal piece....not sure what that is but it's easy to remove. Also, once everything is loose you have to tilt the dash bezel one way or the other(top back/bottom out or visa versa). It took me a couple of times of tilting (and holding my mouth right as my dad used to say), but came out easily.
Mike
'72 Cheyenne LWB 350/350
"The sun don't shine on the same dog's ass all the time." - Catfish Hunter (commenting on why he was not able to pitch another perfect game).
Mike Culpepper is offline   Reply With Quote
Old 05-27-2003, 06:56 PM   #10
Longhorn Man
Oh yeah, if you have a stock tach in there (or an aftermarket one in the tach hole for that matter) you'll need to drop the column a little.
Old 05-28-2003, 10:24 PM   #11
pat
pat's Avatar
Thanks everybody. Now I just need a spare second or two.
Old 05-28-2003, 10:43 PM   #12
70CST1
70CST1's Avatar
FIRST YOU NEED TO DROP THE COLUMN THEN YOU NEED TO GET A FOUR POUND HAMMER THEN COMMENCE TO BEATING. THAT SEEMS TO BE THE EASIEST WAY BUT THE REINSTALLATION REALLY STINKS.
70CST1 is offline   Reply With Quote
Old 04-02-2012, 02:00 AM   #13
KY Colonel
KY Colonel's Avatar
Re: How do I remove my dash bezel?
Subscribed
1970 K20 Custom 427/TH400/PS/PB and a dash of badass!
I was made in America, my truck was too...4 years before me.
KY Colonel is offline   Reply With Quote
