Old 12-26-2012, 11:18 AM   #1
blackbeaSSt
brake time for the 02 burb. need pad ideas
first time since we've owned it that the brakes will need to be done.
are all pads created equal for this beast?
im looking at these for the front and these for the rear for about $80+ tax.
blackbeaSSt is offline   Reply With Quote
Old 12-26-2012, 11:38 AM   #2
hyatt
Re: brake time for the 02 burb. need pad ideas
If you buy at part store they usually have 3 grades always buy the BEST Money well spent If not go to dealer and buy oem There is a difference
1946 car hauler
1948 surburban
1937 chevy sedan
1940 olds sedan (project)
1967 ss396 chevelle
1999 dually crewcab(24000 miles)
hyatt is offline   Reply With Quote
Old 12-26-2012, 11:52 AM   #3
blackbeaSSt
as far as exact fit those look to be the best advance auto has to offer with good ratings. they are about $65 a set. then there is a $50 off coupon code to make them $80+ tax
Old 12-26-2012, 12:11 PM   #4
blackbeaSSt
but then again i can get these for the front and these for the rear for about $45 +tax
or the platinum version for about $60 +tax
Old 12-26-2012, 02:19 PM   #5
blackbeaSSt
ok i talked to my mechanic and he said that if ceramic pads aren't recommended that he wouldn't suggest putting them on due to the squeaking affect it might cause.
so are ceramics ok to put on or the semi-metallic?
Old 12-26-2012, 05:19 PM   #6
crazy longhorn
Fabricate till you "puke"
I used the Wagner themo quiets on my o2 silverado, & am happy with the set crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-26-2012, 07:03 PM   #7
blackbeaSSt
i popped for the wearever gold series for $47 total. guess i'll see what happens
Old 12-26-2012, 09:21 PM   #8
Boog
laying low
Boog's Avatar
I ran the Wagner Ceramics for years on my 97 Burb and loved them. Quiet and low dust emitting.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 12-27-2012, 12:34 PM   #9
blackbeaSSt
yeah i decided to go with the cheapies for now. if they suck or squeal then i'll try the wagners.
Old 12-27-2012, 02:41 PM   #10
bighaas79
i too went the thermo quiet on my 02 1500hd front and rear. went thru 2 sets of annoying screeching with them. (the old brakes were silent just getting worn) Even with all new rotors, pads, clips, cleaned and greased properly they would be fine for about a week and a half then start screeching. finally made them warranty from the thermo quiets to perfect stops. Been alot happier with those than the thermo quiets.
bighaas79 is offline   Reply With Quote
